Tell Us What You Did To Your EG/EK/Del Sol Today - Honda-Tech
Old 08-20-2009, 04:20 PM   #1
knightsef-eg's Avatar
Icon6 Tell Us What You Did To Your EG/EK/Del Sol Today
just for fun...
my gf`s first car she picked up for 900 bucks today
97 cx. .unmolested and stock..original keys and key chain as well
slam , tuck , clean , and gsr swap ..
anyone know if 94 integra koni yellows struts will work on the ek?
knightsef-eg is offline   Reply With Quote
Old 08-28-2012, 08:32 PM   #2
purgat0ry's Avatar
Default Re: *** Official What You did to your eg/ek today ***
Quote:
Originally Posted by Kohen View Post
Holy slammed.
wryyyyyyy do people slam cars like that, jeebus!
That can't be comfortable NOR safe in any sense of the imagination.
Don't get me started on the propped hood like that.
purgat0ry is offline   Reply With Quote
Old 08-28-2012, 08:47 PM   #3
i spent the day replacing the fuel lines on my 93 civic dx, complete PITA! but its all done now. hard line under the car and flex line from the axel to the filter.
Element3488 is offline   Reply With Quote
Old 08-28-2012, 08:47 PM   #4
Kohen's Avatar
Kohen is offline   Reply With Quote
Old 08-28-2012, 09:38 PM   #5
I bled my brakes after putting on a new caliper in the rear of my 97 civic.....It was supposed to be an easy swap...wow was I wrong...
dc2012 is offline   Reply With Quote
Old 08-28-2012, 10:06 PM   #6
What made it difficult? calipers are cake to replace on our cars.
jbpnoman is offline   Reply With Quote
Old 08-29-2012, 05:17 AM   #7
eg6bpd's Avatar
this should be on by friday :D
eg6bpd is offline   Reply With Quote
Old 08-29-2012, 06:15 AM   #8
Hi Guys, just accomplished installing rear disc brake for my honda civic vti:
elmermanansala is offline   Reply With Quote
Old 08-29-2012, 06:45 PM   #9
Master Detailer
98civdx's Avatar
Walked into garage, looked at it and walked out.
On an actual note, I went out to finish rebuilidng my calipers only to find that the pistons are gone.
98civdx is offline   Reply With Quote
Old 08-29-2012, 06:59 PM   #10
Crazy Honda Guy
Deetz's Avatar
Today, i made a decision!!!!! Get my damn EM1 out of storage, even if it is just for a month or two, and get my engine swap done.....the one i rebuilt two years ago
Deetz is offline   Reply With Quote
Old 08-29-2012, 07:02 PM   #11
purgat0ry's Avatar
Got the R Right RTA back on the car.
Found out I need a new front right upper control arm, ******* threads are wrecked some how, not to mention there is a big of play in the socket, ugh...
Old 08-29-2012, 07:07 PM   #12
Can anyone tell me.how to remove the back fender? I need to bang out a dent
PacMann75 is offline   Reply With Quote
Old 08-29-2012, 08:23 PM   #13
the rear fender is part of your cars chassis, it doesnt come off.
thats why those rear quarter dents are such a PITA
sorry
EG-McNutt is offline   Reply With Quote
Old 08-29-2012, 09:07 PM   #14
Master Detailer
98civdx's Avatar
Quote:
You still aren't done!?
Quote:
It's spot welded on, it doesn't come off easily.
Old 08-29-2012, 09:22 PM   #15
Washed and waxed my daily EK today
h2beezy is offline   Reply With Quote
Old 08-29-2012, 09:32 PM   #16
redm3turbo's Avatar
redm3turbo is offline   Reply With Quote
Old 08-29-2012, 09:34 PM   #17
redm3turbo's Avatar
lot of propped hoods are b/c clearance....alot of v6's out of cl type s are running around ny at least under hoods of civics.
Ill deal with the propped hoods, its when they notch em out and let the engine show through the hole that i draw the line.
Old 08-29-2012, 09:49 PM   #18
Crazy Honda Guy
Deetz's Avatar
Quote:
I never even drove the year this year, at all It's been in storage in a different city, somewhere safe. Last summer was kind of a write off for me too, all i did was work 60 hours a week and had no life.
I think i will use this Sept to really try and finish off the car. Install the new engine and tranny, readjust the rear of my suspension and bring it up a little to improve ride quality, plus drop it off at the body shop to refinish a new oem rear bumper and install a matching rear accessory lip (was tough to find, but glad i did)
Old 08-29-2012, 10:45 PM   #19
Kohen's Avatar
Quote:
Originally Posted by redm3turbo View Post
LMFAO!
But seriously,
I bought one for like $100 I think.. Worked nicely. It's called a stud gun dent puller. Check places like Harbor Freight and online even.
Old 08-29-2012, 10:48 PM   #20
Master Detailer
98civdx's Avatar
Damn. I though you would have finished it for sure. lol
It's too bad she'll be right back into storage for winter.
It's good you have a place to keep it safe during the winter!!
You're not the only one though. This summer was supposed to "big" summer for my civic. I did nothing.
Old 08-31-2012, 10:30 PM   #21
Ryank327's Avatar
Put about 6 more hours into prepping for the refinish, full project thread:
http://honda-tech.com/showthread.php?t=3083492
Ryank327 is offline   Reply With Quote
Old 09-01-2012, 01:20 AM   #22
This is what I've done today.
-Took out the timing belt cover to check the TDC.
-Turn the crank pully counter clockwise till the white mark is lined up with the two markers on bottom timing belt cover. (Pic 1)
-While turning the pully, I stuck a long screw driver to check if the cylinder 1 is at it's top most position and it was.
-While the valve cover was off I -
- replaced valve cover gasket and spark plugs gasket.
- took out the VTEC solenoid and cleaned it and replaced the gasket (which only found at dealer for 20 bucks ).
- checked for valve movements if any loose ones and none.
- checked for valve clearance and they are within spec.
-Took out the exhaust manifold all the way to CAT converter to check if any clogged. (The spring bolts were pain to put back in...)
-Replaced the exhaust manifold gasket.
-I took the intake manifold out to check and clean.
-Replaced the intake manifold gasket.
-Took the TB out and cleaned it.
-Took the FITV out of TB and cleaned that also.
-Replaced little gaskets from FITV.
-Replaced TB gasket.
-Cleaned IACV.
-Tried to clean the fuel injectors with carb cleaner and let it air dried.
-replaced fuel filter.
-replaced spark plugs (NGK plugs that are described under the hood).
-replaced spark plug wires.
-replaced distributor O-ring, rotor and cap.
-cleaned the distributor. (outside only)
-flushed the radiator.
Ryan Lwin is offline   Reply With Quote
Old 09-01-2012, 05:21 AM   #23
I just had my spark plugs and oil changed in my converted d15B engine.
I just had it fully synthetic and replaced my old NGK spark plugs with a platinum one.
I also had my timing belt and aircon belt replaced.
My car is a 97 VTi 4 door sedan going on her 110k+ run.
BigBunnyBoi is offline   Reply With Quote
Old 09-01-2012, 09:21 AM   #24
Quote:
Originally Posted by Thmanx View Post
Smogged/Ref'd the C5
What's up dude nice car you got there one question your mother is jdm right how you did it to make it legal thanks ?
Estuardo1025 is offline   Reply With Quote
Old 09-01-2012, 09:23 AM   #25
I'm really sorry about that I'm really sorry misspelled I meant to put your motor I'm sorry dude
Del Sol front sway fit on EK? POE Honda Civic / Del Sol (1992 - 2000) 8 06-28-2016 07:30 PM
del sol no key for tires help!! del sol1993 Honda Civic / Del Sol (1992 - 2000) 7 09-30-2015 09:16 AM
honda del sol del sol1993 Introduce Yourself 0 09-15-2015 10:44 AM
Are del sols for the fruity? White_EG1 General Discussion and Debate 13 03-29-2015 09:10 PM
WTB: EK, EG, (HATCHBACK) OR DEL SOL SHELL! FL ONLY! JDMrasta Want to Buy 3 08-17-2006 03:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
