Targa top seals
Old 10-19-2006, 01:33 PM
Tazragoon's Avatar
Default Targa top seals
how do i replace the seals on a targa top for my del sol? where can i get them? i also have a leak along where the window meets the roof... it that also the seals or do i jsut need to adjust the window to go up more?
Old 10-19-2006, 02:29 PM
postman's Avatar
Default Re: Targa top seals (Tazragoon)
try adjusting before replacing
Old 10-19-2006, 06:00 PM
Tazragoon's Avatar
Default Re: Targa top seals (postman)
well it isn't just leaking form the windows so i have to replace regardless
Old 10-19-2006, 08:20 PM
EG2Driver's Avatar
Default Re: (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote">what year... id try to adjust first... the replacement seals are like $500+</TD></TR></TABLE>
Yea it is that expensive. Honda told me it was that much because it doubles as the gutter and seal. Best bet is to go to a junkyard.....even better bet is to get 1995+ seals as they were revised that year. There are two screws on the door jamb and two fasteners at the headliner. Otherwise, its just "pressed" on.
Old 10-19-2006, 09:26 PM
Tazragoon's Avatar
Default Re: (DeadEnd9009)
well where can i find the parts and what are the names of them exactly... is it possible just to find a 95+ targa top to use?
Old 10-19-2006, 09:30 PM
the.hamburglar's Avatar
how do you adjust?
Old 10-20-2006, 07:40 AM
EG2Driver's Avatar
Default Re: Targa top seals (the.hamburglar)
you dont adjut the seals, you adjust the place where it locks the roof in place.
Old 10-20-2006, 09:04 AM
jdeemseerx's Avatar
look up the how-to's on teamdelsol.com "tightening up the targa top" i did this and it stopped the leak on the pass side, but still dripped a little bit right on my knee.. so on the drivers side this is what i did:
if you take off your door panel but leave your connectors for the p.w. connected.. youll see two 10mm at the top of the door skin that serve as "stoppers" for the plastic on the regulator.
There is an adjustment if you look closely youll see 3 horizontal lines about 1/4" apart.. mine was all the way on the bottom..
Loosen the bolt, slide it to the top..tighten and test if it still leaks
I also lubed my seals at the same time as i did all this,, GL and welcome to the world of having a Sol
GC7
05-15-2018 02:08 PM
Neptronix
13
01-16-2012 05:12 AM
Oregon
03-20-2007 04:40 PM
Ecskater1313
04-02-2004 10:29 PM
chhuong
05-13-2003 12:36 PM
Quick Reply: Targa top seals
