T bracket?
Re: T bracket? (mercutio_07)
If you can get your hands in there to unbolt the bolt that attaches the T bracket to the mount and the 3 bolts from the rear mount to the subframe, then yes. It is ridiculously difficult to unbolt the T bracket from the mount, though. I've tried.
I would say it might be easier going in from underneath, unbolting both the rear mount and T mount, then dropping it down. Requires some finaggling to get it out, though.
Re: T bracket? (Blk00EJ8)
that's just it though...i've gotten in there and taken out all the bolts attached to the mount (definitely a pain in the a$$), but there's a hose in the way from me pulling it out, even when the hose is off it's attachment sticks out too far and that's in the way.
Why are you against taking out the T bracket? From under the car, it's just 4 bolts. Very easy. Then remove the rear mount, replace, and throw 4 bolts back in. It's pretty darn simple.
Re: (Bakeoff)
I'm not against it, just didn't know if there was a way to take out the mount without taking that out. After enough failed attempts to get it out without taking off the T i would've taken it off, but it started raining...
mateo5046
04-14-2008 01:04 PM
91BlueEF9
09-08-2007 07:00 AM
XkjeldorX
06-21-2006 01:49 PM
