Synthetic vs. Non-synthetic Transmission fluid - Honda-Tech
Old 06-16-2002, 11:43 AM   #1
Si_Allen's Avatar
Default Synthetic vs. Non-synthetic Transmission fluid
I am wondering what is better to run in my 1992 civic si hatch. I bought some mobil one fully synthetic transmission fluid but haven't put it in yet. Also how often should transmisson fluid be changed? Tell me what you all think, what do you all run how does it treat you? thanks -Allen
Si_Allen is offline   Reply With Quote
Old 06-16-2002, 11:46 AM   #2
neveronlines2k's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (Si_Allen)
I run neo trans fluid and I change mine every 20,000 to 25,000. I think recomends every 30,000. I like the NEO fluid I would recommend it
neveronlines2k is offline   Reply With Quote
Old 06-16-2002, 03:21 PM   #3
ejprimo's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (stuckatworksi)
i use the mobil 1 syn. tranny fluid...it works fine
ejprimo is offline   Reply With Quote
Old 06-16-2002, 03:23 PM   #4
buzlink's Avatar
I use AMSOil synthetic in mine.
Works great so far. Oh and its a synthetic. Expensive ****.
buzlink is offline   Reply With Quote
Old 06-16-2002, 03:44 PM   #5
VXpride's Avatar
The tranny fluid works good.
VXpride is offline   Reply With Quote
Old 06-17-2002, 04:49 AM   #6
D Tranny Guru
Mista Bone's Avatar
10w30 or Honda MTF. The Mobil Syn. tranny fluid is for automatics.
I know D trannys, do YOU?
Mista Bone is offline   Reply With Quote
Old 06-17-2002, 04:53 AM   #7
IdotheSHOCKER's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (Mista Bone)
Another Mr. Bone "TuDe" thrown at us.
IdotheSHOCKER is offline   Reply With Quote
Old 06-17-2002, 05:53 AM   #8
D Tranny Guru
Mista Bone's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (EGB18hatch)
I guess you have nothing better to do but go around CRYING because you are clueless and have no idea.
Research is key.
Old 06-17-2002, 03:55 PM   #9
Si_Allen's Avatar
It says on the the bottle I have here in my hand that it offer maximum protection for manual transmissions where an API GL-5 quality oil is recommended. What is recommended for a d=series tranny? Sounds like its meant for manual and automatic trannys.
Old 06-17-2002, 03:56 PM   #10
Si_Allen's Avatar
ttt
Old 06-17-2002, 06:35 PM   #11
ejprimo's Avatar
you dont buy mobil one transmisson fluid cuz thats for auto. you buy the mobil one gear oil.
Old 06-17-2002, 06:52 PM   #12
shawnhayes's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (ejprimo)
Although Mobil one gear oil may be acceptable for Honda manual transmissions (because of superior formulation, and the fact that gear oil is close to motor oil), the manual specifies MOTOR OIL. A more appropriate fill would be Mobil-1 10W-30 (as specified in the manual).
Shawn
shawnhayes is offline   Reply With Quote
Old 06-17-2002, 07:36 PM   #13
Plan B's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (shawnhayes)
mobil 10-30 is good,
don't use redline, not good for honda's.
Plan B is offline   Reply With Quote
Old 06-17-2002, 08:28 PM   #14
JeffS's Avatar
Keep in mind guys that the things that make an oil good for an engine aren't necessarily good qualities for a transmission. In an engine, wear properties, heat resistance and overall friction are important. The tranny is subjected to much less of these stresses. The syncro's in a honda tranny need a certain amount of friction to work properly... meaning that if you use some super-slippery lubricant it might be great for the gears, but would result in torn up synchro's.
There's stories of people running into problems after using various synthetic oils in the transmission. Most of them seem to be heresay though. Personally, while I run Mobil1 in my engine, I choose to stick with Honda MTF for the trannies. Wear is rarely the thing that kills a tranny anyway... it's abuse such as mis-shifts, forcing into gears, etc...
JeffS is offline   Reply With Quote
Old 06-18-2002, 07:09 PM   #15
shawnhayes's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (JeffS)
Would 100,000 miles of trouble free operation of my 1992 Honda Civic with Mobil-1 motor oil as the transmission fluid sway you at all?
Shawn
Old 06-18-2002, 07:19 PM   #16
honda does not recommend syn. tranny fluids..30w dino. juice works best
deepnite is offline   Reply With Quote
Old 06-18-2002, 07:21 PM   #17
yup, yup
Old 06-18-2002, 07:22 PM   #18
Si_Allen's Avatar
sounds good to me. I like to here all this info to make a more educated decision. ttt
Old 06-18-2002, 07:46 PM   #19
shawnhayes's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (deepnite)
Ummm. Honda doesn't recommend 30W. Its absence from the manuals confirms that, but where does Honda recommend against synthetics?
Shawn
Old 06-24-2002, 10:31 AM   #20
Si_Allen's Avatar
ttt
Old 06-24-2002, 10:36 AM   #21
SIINSI's Avatar
I just put in BG Synchroshift Synthetic MTF. Works AWESOME....
Also, here is a post I recently made and you can get some more views on it.
http://honda-tech.com/zerothread?id=213002
Also, you can buy it here...
http://www.machv.com/bgsynchroshift.html
Hope that helps.
Miguel
SIINSI is offline   Reply With Quote
Old 06-24-2002, 12:21 PM   #22
Kamin's Avatar
honda MTF
Kamin is offline   Reply With Quote
Old 06-24-2002, 01:36 PM   #23
Charles B.'s Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (KAMiN)
i use the mobil 1 sythetic gear oil 75w-90
Charles B. is offline   Reply With Quote
Old 06-24-2002, 01:37 PM   #24
DragII's Avatar
Quote:
honda MTF
DragII is offline   Reply With Quote
Old 06-24-2002, 01:50 PM   #25
Viorent GRIP!'s Avatar
Im running Honda ATF. Had Redline before a lil too slick for my worn 3rd gear, it kept crunching, threw in some ATF boom crunching subsided. yay!
Viorent GRIP! is offline   Reply With Quote
full synthetic and Synthetic blend OMGdjdy Engine Management and Tuning 3 04-05-2010 08:13 PM
What is the toughest allen wrench? handa Honda Civic / Del Sol (1992 - 2000) 12 07-22-2008 02:05 PM
What tranny fluid you run in your EP3? square_1 Acura RSX DC5 & Honda Civic EP3 8 10-10-2007 08:54 PM
How do you get 3 bolts off of 92-95 catalytic converter??? Si_Allen Honda Civic / Del Sol (1992 - 2000) 18 12-28-2002 06:40 AM
Benifits of Synthetic Brake fluid vs..non-synthetic? IM ALL BOB Road Racing / Autocross & Time Attack 2 01-03-2002 10:17 AM
Tags
1999, 75w90, atf, automatic, bg, castrol, fluid, good, honda, lancer, mitsubishi, prelude, put, syntec, synthetic, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
