symptoms of bad IAT sensor? - Honda-Tech
Old 10-30-2005, 05:42 PM   #1
black sohc civic's Avatar
Default symptoms of bad IAT sensor?
i ran my cel today and got 10 long pauses and 1 quick one
i think this is the IAT can anyone confirm?
for a few days now i have been hearing a sucking sound in my engine bay and at idle the rpms bounce up and down a little bit
bad IAT? or something else
any help is appreciated ...
black sohc civic is offline   Reply With Quote
Old 10-30-2005, 08:02 PM   #2
Simple's Avatar
Default Re: symptoms of bad IAT sensor? (black sohc civic)
re-read your code, you just told everyone you had code #101... there is no code 101... a IAT is just a sensor that monitors your air intake temp sensor and corresponds with teh ECU along with other sensors such as the map and tps to give your engine more, or less fuel.... could it cause the idle bounce? that im un-sure of... usually that has to do with a vaccum leak
Simple is offline   Reply With Quote
cant tune s300 , IAT reads 129.4 degress F 93delslow315 Engine Management and Tuning 4 08-22-2012 04:11 PM
intake air temp? ama11 Tech / Misc 3 09-06-2010 11:21 AM
symptoms of bad IAT sensor? black sohc civic Tech / Misc 2 10-30-2005 09:18 PM
skunk2 Intake manifold on first gen b16 roadawg Honda CRX / EF Civic (1988 - 1991) 5 03-13-2004 10:13 PM
IAT valve/sensor gsrcivict For Sale 4 10-14-2003 05:51 PM
Tags
air, bad, civic, crx, defective, honda, iat, intake, map, sensor, signs, symptoms, symtoms, temp, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
