Symptoms of BAD differential bearings? - Honda-Tech
Old 08-28-2005, 07:43 PM   #1
crexer's Avatar
Default Symptoms of BAD differential bearings?
I hate to make another thread but this one is a bit more specific and there is no material to find when I did a search on these bearings. Have bad differential bearings #16, would this cause the tranny to make any sounds or noises? When the top one is spun it sounds like a skateboard wheel a bit louder than the rest of the bearings. Im replaces the input shaft bearing but it didnt see to make any noise when spun. So what would bad differential bearings sound like in gear, accelerating or at idle, clutch pushed in or out?
crexer is offline   Reply With Quote
Old 08-28-2005, 08:23 PM   #2
crexer's Avatar
Default Re: Symptoms of BAD differential bearings? (crexer)
gettin desperate here
Old 08-28-2005, 08:39 PM   #3
Jim Truett's Avatar
The diff bearings only turn when the wheels turn. The symptoms of bad diff bearings include whining, grinding, or rumbling coming from the drivetrain while the car is moving, and the pitch or frequency changes with vehicle speed.
Jim Truett is offline   Reply With Quote
Old 09-01-2005, 02:21 PM   #4
roydogg's Avatar
Default Re: Symptoms of BAD differential bearings? (Jim Truett)
Quote:
I'm having a sound like it's binding coming from the trans only when i turn. Bought the motor from HMOnline and the car drives fine when I go straight but makes a crazy noise like I have a bad axle when I turn. Axles were already replaced too.
How hard is it to replace the differential?
roydogg is offline   Reply With Quote
Old 09-01-2005, 03:05 PM   #5
Chiovnidca's Avatar
Quote:
They can sound kind of like a bad whell bearing. I've seen a couple that only made noise going around sharp turns @ 30mph+.
If you spin any transmission bearings by hand they shouldn't feel rough.
Chiovnidca is offline   Reply With Quote
Old 09-01-2005, 03:23 PM   #6
crexer's Avatar
Default Re: Symptoms of BAD differential bearings? (Chiovnidca)
I replaced the input shaft bearing, throwout bearing and pilot bearing, put the tranny back together and it couldnt be any better. Shifts very smooth and is super quiet.
Wheel Bearing Phil_46 Honda Civic / Del Sol (1992 - 2000) 4 06-11-2013 10:16 PM
transmission questions (differential/oil/bearing) eda6 Honda CRX / EF Civic (1988 - 1991) 8 01-26-2008 04:26 PM
sound of bad needle bearing vs. ball bearing? davidluko Tech / Misc 2 01-21-2007 04:57 PM
Tranny problem. sy1 non LSD G2ILS Acura Integra 3 07-21-2005 07:04 PM
Spun bearing?? Sephro Honda Prelude 11 11-09-2004 12:10 PM
Tags
axle, bad, bearing, bearings, civic, differential, diffrential, honda, integra, noise, signs, sound, symptoms, transmission, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
