Swapping JDM D15B VTEC from EG to EK
Old 02-02-2010, 10:34 AM
Momentum's Avatar
Default Swapping JDM D15B VTEC from EG to EK
Hey guys, I just purchased a 92 civic hatch with a boosted JDM D15B VTEC for $1500. Ive owned a few civics with swapped motors before, but never actually done the swap myself and would like to do it my first time here.
Reason for swapping:
D16Y7 is getting old at 280,000 km's and starting to burn some oil, and I got the EG for cheap... once i part out interior and body parts, sell the rims, suspension and exhaust I should have gotten a built D15B and turbo kit for pretty much free.
My question for you guys is what all needs to be done to swap this into my 2000 Civic DX with a D16Y7. Im hoping it should be simple since they are both D-series.
I know i need to:
Convert from OBD-2 to OBD-1
Wire for VTEC
Will my mounts workÉ
Do i use the engine harness already in the EK and just add in whatever I need for vtec? Then i will need a conversion harness that connects the OBD-2 engine harness with the OBD-1 ECU? Or how does this work?
I can look at write-ups online for these things... but is there anything else that i need to do or will everything else fall right into place?
Thanks guys!
List of parts from D15B:
Mild built block
JDM D15B VTEC
fully built bottom
ACL race bearings speced over
micropolished JDM d15b crank
eagle rods
vitara low comp pistons
ARP rod bolts
Hasting rings
New OEM water pump
New OEM oil pump- ported for better oiling
Head was deassembled and checked over
ARP head bolts and studs
resurfaced fly wheel
Stage 3 6 puck clutch
log style turbo manifold
garrett airresearch turbo
custom down pipe
custom intercooler pipping
large unknown intercooler-29" by 11" by 2"
Greddy type s bov
vibrant couplers
jdm H22 PRELUDE injectors
MSD 8mm wires
255LPM walbro pump
dual core aluminum rad
12 inch slim fan
chipped P28
Hondata s200 stage 4b
custom exhaust 2.5
b&m short shifter
Old 02-02-2010, 11:18 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: Swapping JDM D15B VTEC from EG to EK
this is tuff one. cuz its an older motor.
use your obd2 harness. but the obd1 dizzy and altenator will have dif plugs.....
so get obd2 alt and dizzy or adapter plugs.
you will need the obd2 to obd1 ecu harness adatper $40 on ebay.
Old 02-02-2010, 12:09 PM
Momentum's Avatar
Will i be able to use the alternator and distributor off of my y7 for the d15b? or just buy adapter plugs?
As for the jumper harness, is it something that i should buy from a quality brand or will an ebay harness be just fine?
Old 02-02-2010, 12:12 PM
I'm not Rick!
you can use the other ones. they will bolt on
ebay harness will work fine.
its just wires and plugs. they are good products i bought a few
http://cgi.ebay.com/New-OBD2B-OBD1-J...item2eaac55a19
Old 02-02-2010, 12:19 PM
Momentum's Avatar
Well that particular seller doesnt ship to canada, but i just bought a harness from another seller for $42.00 canadian shipped.
Thanks for clearing up the alt and dizzy thing. Anything else i need to worry about?
Old 02-02-2010, 01:29 PM
sde780's Avatar
can't you just buy obd2 -> obd1 jumper and use your obd1 harness?
Or keep it obd2 - re-use the y7 dizzy, IM, etc
Old 02-03-2010, 05:54 AM
I'm not Rick!
obd2 engine harness is 1 piece. obd1 is 2 peice. there is a way to use it but i dont remember how. and you have to cut stuff
Old 02-03-2010, 11:49 AM
Momentum's Avatar
So i ordered the right harness correct? To use the P28 ecu and my y7 harness.
http://cgi.ebay.ca/ws/eBayISAPI.dll?...=STRK:MEWNX:IT
Old 02-03-2010, 12:38 PM
I'm not Rick!
^yup now GL.
Old 02-07-2010, 11:32 AM
F-FORD!'s Avatar
i recently bought a jdm obd2 d15b with plans of boosting it. unfortunately i didnt know that this was a crap motor. as it comes with teh 3 stage vtec.
my question is, can i use a z6 or a y8 head on this and is it a straight bolt on?
also is this block the same as the z6 and y8?
id like to use the vitara kit from fj distributor.... but am not sure of this kit is ok to use on the obd2 d15b 3 stage vtec block.
someone please help. im stuck here and dont knwo what to do. ive researched this everywhere but no one knows much about this motor
thank you
Old 04-20-2010, 05:05 PM
Momentum's Avatar
Alright so im almost ready to do the swap, D15B is out and im just cleaning it up. I have a chipped p28 and will be using my obd2b harness using a jumper.
I will be using the obd2 dizzy an alt. (can i use obd2 dizzy and alt from a non-vtec motor on the obd1 vtec motor?)
i have read that i may need to use obd2 injectors (which means i will need to buy bigger obd2 injectors) do i use obd1 or obd2b injectors?
Also read that my harness has a knock sensor but there is nowhere for it on the d15b. Do i just cut of off?
Old 06-16-2010, 08:11 PM
Momentum's Avatar
Update:
Will DSM 450cc injectors work with the D15B?
Old 04-03-2011, 10:35 AM
civic919900's Avatar
I need some info on this as well. My y8 is shot and burns crazy amounts of oil. Planning on doing the same swap.
want2drive
06-14-2011 10:11 AM
xsaxisx
04-27-2011 08:03 PM
project_bluff
03-02-2011 03:47 PM
egvtec
08-18-2008 08:20 PM
colour-flip
11-03-2005 10:06 AM
Quick Reply: Swapping JDM D15B VTEC from EG to EK
