Suspension popping noise
Old 10-13-2013, 11:36 PM
memo_ej8's Avatar
Default Suspension popping noise
About a month ago my axle pretty much exploded,but prior to that it'll make loud thump/pop noises when ever I turn the wheel. So after I figured that's why my axle blew up. So I replaced it, also I replace my lower ball joint, and the outer tie rod. I put in my new axle and went out for a spin. It'll make that same thump/pop noise but this time only when I get out my driveway, or when ever I turn the wheel all the way. Can it still be the axle? What else can it be? Help don't want my axle to blow up again
Old 10-14-2013, 12:15 AM
CO671's Avatar
Default Re: Suspension popping noise
What vehicle, year, and trim, any suspension modifications?
Old 10-14-2013, 12:36 AM
memo_ej8's Avatar
It's a 96 civic ex coupe. It's lowered on function & form type 2 coilovers
Old 10-14-2013, 12:54 AM
CO671's Avatar
Try the 3-9 horizontal test and the 12-6 vertical test to see if it's either the tie rods or the wheel bearing are at fault.
Inspect the shock tower too
Check the front sway bar endlinks if they're worn and need replacing. Or even just remove the front sway bar and drive a bit to see if the noise goes away
(I'm not entirely sure if EX's came with front sway bars in the first place, but this is a common problems on CRV's so I wouldn't be surprised if it's the same for Civics)
phen10
06-25-2019 07:34 PM
Inextricabledrvr
07-25-2014 08:53 PM
Flyboy4yang
Suspension & Brakes
13
04-21-2007 06:02 PM
LST2
Suspension & Brakes
06-05-2006 06:21 AM
rustycivic
03-07-2003 09:55 AM
Quick Reply: Suspension popping noise
