pics of needed trans mounts for auto-manual swap
Old 11-11-2011, 10:18 PM
vartok's Avatar
Default pics of needed trans mounts for auto-manual swap
Im getting the parts together to replace my 93 LX's auto for a SI manual 5speed. Ive got mos of the parts located, but could someone post any pics they have of the trans mounts thant need to be replaced so that i know what im looking for? i know the upper mount needs a conversion mount, but im not 100% on the other mounts.
Also any advice on doing this swap would be greatly appreciated
Old 11-11-2011, 10:40 PM
Linked's Avatar
Default Re: pics of needed trans mounts for auto-manual swap
the mount is called 92-95 auto to manual transmission mount, about 125$ from has port and from innovative
Old 11-11-2011, 10:53 PM
vartok's Avatar
Oh I know that one, I'm talking about the others, I'm trying to find the on eBay or something and pics of the manual mounts would really help out.... Junkyard is not an option, non of them ever have civics
Old 11-12-2011, 07:49 AM
Seagull Management
94EG8's Avatar
you don't need to change the rest of them, you will need the metal bracket for the front lower torque mount though that bolts to the transmission. Can be found on any '92 - '95 5 speed civic. (actually IIRC '96 - '00 is the same as well) the rubber mounts with the exception of the transmission mount that you need to replace with the swap mount can all be retained, but the manual versions are stronger.
Old 11-12-2011, 08:08 AM
northcb7's Avatar
Heyy dude I have an innoative
mount for auto to manual conv. For an integra. If u want it, let me kno.
Old 11-12-2011, 01:02 PM
Linked's Avatar
DO NOT GET THE EBAY MOUNT
i have the ebay mount and it was the worse decision i ever made,
2 months after i did the swap, the rubber filling inside the mount dislodged itself from the actual housing, it is terrible
spend the extra money so you will not have any problems in the future, i'm begging you
Old 11-12-2011, 01:20 PM
Resident Gearhead
BryanM.'s Avatar
My friend's Innovative mount did that after only a year and a half.
Old 11-12-2011, 01:57 PM
vartok's Avatar
yeah, i wasnt looking at ebay for the conversion mount, but for the manual bracket i needed... like i said, no junkyards around here have civics, so i have to get everything off the interwebs or from a dealer/autoparts store
Old 11-12-2011, 02:22 PM
Linked's Avatar
i never had to swap the bracket on my auto 94 ej1
Old 11-13-2011, 12:48 PM
Seagull Management
94EG8's Avatar
You have to either swap the bracket and run a factory manual mount, or get an aftermarket swap mount. If you did neither you had an engine that sat cockeyed with a really screwed up axle angle on the passenger's side.
Rttix1337
02-09-2014 06:23 AM
kd97accord
04-29-2010 05:06 PM
preludeboybmw
11-22-2007 09:47 PM
deeweezy187
03-06-2007 03:53 AM
origyns
07-05-2005 12:49 PM
Quick Reply: pics of needed trans mounts for auto-manual swap
