sunroof wont open - Honda-Tech
sunroof wont open
Old 05-12-2010, 10:56 AM   #1
CivicSi95's Avatar
Default sunroof wont open
i have a 95 Si. when i push the button it makes a clicking sound but doesnt open the sunroof. i have checked fuses 16 and 19 under the dash and they are both good
CivicSi95 is offline   Reply With Quote
Old 05-12-2010, 12:01 PM   #2
Duc_du's Avatar
Default Re: sunroof wont open
had the same problem. what i did was change the relay for the sunroof. its this 2 little grey thing that powered the sunroof. mine is a em1 so it might be lil diff. give that a try!!! it suck not to have the sunroof not working.
Duc_du is offline   Reply With Quote
Old 05-12-2010, 12:50 PM   #3
I know this is an obvious question.. but have u tried jus givin it a lil push? Mine was doin the same thing, and after tryna go thru wires, it was jus in need of a lil pushing assistance haha
soulja_grl_ej1 is offline   Reply With Quote
Old 05-12-2010, 01:30 PM   #4
jdmh22eg2's Avatar
^+1 to giving a little push my eg Si does that sometimes when it is cold make sure not a hard push and do it to the rear of glass
jdmh22eg2 is offline   Reply With Quote
Old 05-13-2010, 06:37 AM   #5
CivicSi95's Avatar
i tried to give it a little push and that did not work. also, my intermittent wiper is not working. my other wiper speeds work. could these 2 be related to the same problem?
Old 05-13-2010, 06:40 AM   #6
Dub9.Juice's Avatar
must be relays or motors man but yeah i say check your motors and when and if you get your sunroof popped make sure yo grease the rails it helps somewhat
Dub9.Juice is offline   Reply With Quote
Old 05-13-2010, 06:44 AM   #7
CivicSi95's Avatar
i replaced my main relay just last week
Old 05-13-2010, 09:08 AM   #8
jdmh22eg2's Avatar
^ he means the relay for just the sunroof
check www.hondahookup.com they have many full manuals for download via PDF file should tell u were to find a relay
Old 05-13-2010, 09:14 AM   #9
Former User is offline   Reply With Quote
Old 05-13-2010, 09:21 AM   #10
Duc_du's Avatar
Quote:
main relays and sun roof are diff my friend. pop out ur dash under the wheel. there should be grey relays. try switching them. what happen to mine was that one of the relay gone bad so i was only able to open and not close. when i switch i was able to close and not open. this might be the problem. could be the motor as well. good luck
Old 05-13-2010, 10:00 AM   #11
Same thing happened to me, but part of my wind deflector arm had broken off and gotten trapped. I eventually just messed with it till it gone so far back it didn't interfere with the operation of the sunroof anymore.
Wdpfreak145 is offline   Reply With Quote
Old 05-15-2010, 06:53 PM   #12
Thanks! =] I do kno a thing or two! haha jk
Old 08-11-2010, 06:54 PM   #13
CivicSi95's Avatar
was placing a big order of honda parts so i went ahead and bought a new sunroof switch. i changed out the switch and it still doesnt work. any ideas?
Old 08-12-2010, 02:42 PM   #14
CivicSi95's Avatar
bump
Old 08-19-2010, 07:56 AM   #15
CivicSi95's Avatar
still having problems
Old 08-19-2010, 08:21 AM   #16
macson's Avatar
More than likely relay. Been there with the same problem, relay would click over put wouldn't send current to the motor. Only difference is that mine wouldn't close (real fun, right)? Try tapping the relay a bit with your hand or a screwdriver, see if it frees up, could check the terminals on it as well. If anything, just replace it.
macson is offline   Reply With Quote
Old 08-19-2010, 09:04 PM   #17
i bought a 95 eg hatch a few months ago. sun roof didnt work and after reading this then trying the "push" method it worked. thanks for the help fellas! now onto the clutch and rear main seal replacement.
myevo8urv8 is offline   Reply With Quote
Old 08-19-2010, 10:10 PM   #18
CivicSi95's Avatar
i cant find the moonroof relays when i am looking up under the dash. does anyone have a picture they can post so i know exactly what to look for?
Old 03-24-2011, 11:35 AM   #19
CivicSi95's Avatar
Quote:
Originally Posted by RonJ@HT View Post
i checked every wire to ground and all i hear are clicks. the sunroof doesnt open or tilt. i have not checked the ground wire for continuity cause im not sure what im supposed to do. i do have a multimeter
Old 04-11-2011, 05:57 PM   #20
CivicSi95's Avatar
bump to get my sunroof working
Old 04-11-2011, 06:54 PM   #21
19crx93's Avatar
hey anyone know how to maintain the sunroof? i have a eh3 and my sun roof works but gets stuck when closing have to pull it closed while pushing the button. i would really like to get it to open and close properly. please help. what grease.... how to clean. you know general maintnance.
19crx93 is offline   Reply With Quote
Old 04-12-2011, 02:10 PM   #22
19crx93's Avatar
bumb in the name of keeping the sunroofs working
Old 04-12-2011, 05:07 PM   #23
I had a sunroof on my 95 EJ1 that didn't like to slide. I lubed the tracks with silicone spray lube, and it's worked like a dream ever since.
nerofotia is offline   Reply With Quote
Old 04-12-2011, 10:39 PM   #24
19crx93's Avatar
thanxs dude
Old 04-13-2011, 08:33 AM   #25
CivicSi95's Avatar
please stop hijacking my thread. i still need some help with my sunroof
Sunroof wont open, close or tilt & pm dont work bouncyballs228 Honda Civic / Del Sol (1992 - 2000) 4 05-06-2011 01:13 PM
Sunroof ef-hatchcrap Honda CRX / EF Civic (1988 - 1991) 4 03-04-2009 04:10 PM
sunroof adjustment primetime Honda Civic / Del Sol (1992 - 2000) 2 05-09-2007 06:00 PM
having major sunroof trouble!!! crewjones Acura Integra 4 06-28-2003 08:14 AM
Sunroof has the jitters Tegra Acura Integra 9 08-21-2002 04:09 PM
Tags
92, american, civic, clicking, doesnt, hard, main, makes, motor, open, relay, roof, sun, sunroof, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
