Sunroof problem
Old 08-18-2015, 09:11 PM
Ej8_Travis's Avatar
Default Sunroof problem
My 96 civic sunroof won't open. When I press the button to open it I can hear the motor trying to open the sunroof but it won't move. To me it sounds like something is blocking it. What do you think I should check first? Thanks.
Old 08-18-2015, 11:18 PM
Stancetard Hate Monger
eghatch9295's Avatar
Default Re: Sunroof problem
pop open the access cover and look inside
Old 08-19-2015, 12:43 AM
Mugenkid's Avatar
Maybe it's the switch.. my EG had the same problem got a,new motor too and it still did it.. can you manually close it?
I took the whole thing out to see if it's blockage but saw nothing with the new motor I manually open and closed it.. It was fine
Put it back in and it worked
When I used the switch it opens and closes but the vent setting doesn't I need a new switch.. so try that first...
Pilotperson
07-27-2016 05:33 PM
da1lydr1ver
10-08-2007 12:30 PM
Kovatch EG
14
05-17-2007 12:20 PM
ransack
12-21-2002 05:09 PM
io_burn
14
02-25-2002 05:07 PM
Quick Reply: Sunroof problem
