sunroof drain tubes? Rear floor wet during rain.
My '95 EX coupe is wetting the rear floor on both sides. Could it be the sunroof drain tubes? How many of them are there and how do I get to them?
Any other ideas how my floor might be getting wet?
Re: sunroof drain tubes? Rear floor wet during rain. (serious)
I had the same problem with my crx si. I found out that my drain tubes had plugged up at the ends. On the crx there are four drain tubes, one per corner. The tubes are hidden behind the plastic pillars of you interior. You need to trace them and make sure that the ends aren't clogged like mine were. If they aren't clogged your going to have to remove your headliner and check that the sunroof pan hasn't rotten out, or that the drain tubes haven't seperated from the pan. Hopes this helps.
Wdpfreak145
05-17-2015 10:34 AM
