Suggestions on stripped valve cover bolts (threads in the head)
Old 07-30-2003, 09:00 AM
VXpride's Avatar
Default Suggestions on stripped valve cover bolts (threads in the head)
There's two valve cover bolts that wont tigthen any more on my head (front). I thought that the bolts were just stripped but when i bought new ones and tried them, they would still not get tight. further inspection showed that the threads inside the head are fucked. Anyone else have this problem? is there a temporary fix for something like this? Thanks.
Old 07-30-2003, 09:02 AM
sohc_boy's Avatar
Default Re: Suggestions on stripped valve cover bolts (VXpride)
get some heli-coils.
Old 07-30-2003, 09:28 AM
NonovUrbizniz's Avatar
Default Re: Suggestions on stripped valve cover bolts (sohc_boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy &raquo;</TD></TR><TR><TD CLASS="quote">get some heli-coils.</TD></TR></TABLE>
that or re-tap it.
if part of the bolt body is still stuck in there then just drill it out and re-tap.
Old 07-30-2003, 09:52 AM
RedlinedVTEC's Avatar
Default Re: Suggestions on stripped valve cover bolts (NonovUrbizniz)
I definately second retapping these holes rather than heli coiling them (do they even make heli coils that small?, never seen any). Should be really easy to retap the threads since the head is nice and soft. Off the top of my head those bolts are 6mm X 1.25mm so you'll want to bump up one size.
Old 07-31-2003, 08:53 AM
VXpride's Avatar
Default Re: Suggestions on stripped valve cover bolts (RedlinedVTEC)
ok so i guess i'll just go with retapping them and just getting that size of bolt. what about the bushings that go on the new bolts? guess i don't really need em. Thanks for the info.
Oh and yeah you're right about the bolt size.
4dr_Noob
17
10-18-2011 08:00 AM
turboJDMeg6
03-28-2005 08:21 PM
93civciv
02-27-2005 05:17 PM
lv6l
11-24-2004 07:30 AM
yeegsr
09-23-2004 03:32 PM
Quick Reply: Suggestions on stripped valve cover bolts (threads in the head)
