Stupid question: does the 95 Civic EX Coupe have ABS or not?
Old 07-27-2002, 12:05 PM
M-EJ1's Avatar
Default Stupid question: does the 95 Civic EX Coupe have ABS or not?
Title says it all... I searched, but I could only find info about 5th gen Si's with ABS... does the 95 coupe have it or not?
I ordered some new hawk pads from tire rack, but I believe I ordered the wrong ones... doh.
Old 07-27-2002, 12:30 PM
127.0.0.1's Avatar
Default Re: Stupid question: does the 95 Civic EX Coupe have ABS or not? (matt-eg)
Here is how you check for ABS
1. Get in your car
2. Start car and proceed to the nearest long, straight stretch of road.
3. Get up to about 40 or so MPH.
4. SLAM on the brakes as hard as you can.
If they lock up... chances are you dont have ABS
Or if this way seems too "extreme" for your tastes.. simply open up your fuse box and check to see if you have a ABS fuse inside!!
Old 07-27-2002, 12:37 PM
neveronlines2k's Avatar
some of them did some did not . If you have four rotors than you do have ABS (except for the si's 99-00 ) If you have two rotors and two drums you don't have ABS. I think it may have been a special order but not sure.
Old 07-27-2002, 12:52 PM
rob d's Avatar
stuckatworksi is corect. You can also check for orange wire harness plugs. They used orange for ABS.
Old 07-27-2002, 03:06 PM
Kamin's Avatar
Default Re: Stupid question: does the 95 Civic EX Coupe have ABS or not? (rob d)
it is an option for the 92-95 civics. not standard.
look under your hood, on the same side as the battery look for the big fuse box, (right below the bat.) follow the fender down there is 1 more fuse box below the strut tower, if there is one there. it has abs.
Old 07-27-2002, 05:11 PM
ejprimo's Avatar
Default Re: Stupid question: does the 95 Civic EX Coupe have ABS or not? (KAMiN)
some did, some dont.
2wheelhunter
05-06-2007 07:33 PM
Zing Xiong
27
10-03-2005 12:43 AM
slammed_93_hatch
16
05-12-2005 12:19 PM
pburke23
06-05-2004 11:00 AM
Quick Reply: Stupid question: does the 95 Civic EX Coupe have ABS or not?
