stuck parking brake (e-brake) cable
Old 12-04-2007, 04:54 PM
thebinaryman's Avatar
Default stuck parking brake (e-brake) cable
because i have a 5spd i nearly always use the brake to park the car. recently it's been cold here in wisconsin and on occasional nights the e-brake cable is sticking, the handle will go down, but the wheels are dragging. i took the plastic center panel off:
i should see this:
instead, i see this
if you can't read my ascii art, the passenger side break cable is sticking, and the thingy that connects the cables to the handle is tilted because of the stuck cable. i cannot even force it in with a pliers, i believe it's frozen.
how can i lubricate this or unstick this cable? it probably will unstick itself eventually, but is there a way i can free it now, and in the future just not use the brake when i'ts cold? thanks.
Old 12-04-2007, 05:12 PM
93egSLEEPER's Avatar
Default Re: stuck parking brake (e-brake) cable (thebinaryman)
hot water to get it thawed out is what it sounds like u need. then wd 40 it... then never set it again. i just leave mine in gear.
Old 12-04-2007, 05:16 PM
good idea. where should i apply the hot water and wd-40 though?
Old 12-04-2007, 05:19 PM
Default Re: (thebinaryman)
up next to the handle where it attaches and in the rear where it is stuck... all onder the car of course. you should be able to tell where it is stuck when u get under there.
Old 12-04-2007, 05:21 PM
ok thanks! it's dark and cold outside now, i'll take a look tomorrow morning. i love the fast replies from honda-tech. thanks again!
Old 12-04-2007, 05:23 PM
no prob
flyinfree
09-09-2011 08:55 AM
imadigitalgod
01-05-2010 01:23 PM
ONEhaque
11-10-2008 06:23 PM
HondaHeddie
11-11-2006 04:20 PM
MechEng
12-07-2003 09:13 AM
Quick Reply: stuck parking brake (e-brake) cable
