Stuck Key
Stuck Key
My buddie just got a 94' DX
and it runs great, but the hood wont open and the key is stuck in the ignition, it rotates ok, but it wont come out
thx in advance
thx in advance
Re: Stuck Key (TheRoverSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheRoverSyndrome »</TD></TR><TR><TD CLASS="quote">My buddie just got a 94' DX
thx in advance</TD></TR></TABLE>1.)step on the clutch
2.) rotate key back
3.) pull out
2.) rotate key back
3.) pull out
Re: Stuck Key (brentmc79)
you probably need to replace your ignition cylinder. Happened to me, had to get it towed because wouldnt come out, wouldnt even start the car. Took it to the honda dealership and had to have a new one made to match the door locks.
its an automatic, and we put the other key in the shift lock, tried it in drive, reverse, neutral and park, the car started in neutral, but the key remains stuck.
Re: (TheRoverSyndrome)
is the key bent? it only take alittle bend to make the key stuck. that happened to my uncles nissan altima.
i just kept on pulling and wiggling, it finally came out after 15 minutes .
Sol to Sol
Re: (adaml2nv)
I got my key stuck in the drivers door once(93 Del Sol). It got stuck after unlocking the door, but stopped about 1/8 turn from being able to get it out.
I thought I was going to have to break it off, cause it couldnt move, and I couldnt leave the car sitting in that area, while I ran home and back (about an hour round trip) with another key!
Anyway, when I went to try and break it off in the lock, it finnaly turned and I was able to get it out of the door. Then I nerviously used it to start the car. Had no problems with it sence tho.
BTW, I changed to another key, and put graphite on all the locks sence then!
drew_kousk
10-04-2010 05:57 PM
