strut spring question
Old 08-25-2011, 05:31 PM
tonyhatchetman's Avatar
Default strut spring question
How to know if the springs are bad ? I'm fixing to replace the struts and would hate to find out the springs are bad after I've switched em over .
Old 08-25-2011, 05:57 PM
1991civiclx13's Avatar
Default Re: strut spring question
how does your car sit? does it seem to be ''sagging'' at the rear or the front?
Old 08-25-2011, 05:58 PM
Burton42's Avatar
Generally, from my experience, springs don't go bad. They might experience fatigue but if they are riding ok, no broken and no noises then I think it is a very safe bet that they are good. You might want to upgrade them while your are doing your swap but that is a different question.
Old 08-26-2011, 03:55 AM
It kinda does sit low I figured it was just bad struts but I don't know for sure , I know they haven't been changed and I keep wearing the tires out like dips all around the inside so I figure they are bad .
Old 08-26-2011, 04:34 AM
Ek Forever y0!
Libertariat's Avatar
Springs don't generally go bad.
Are you replacing OEM springs? Replacing OEM shocks? Tell us more about what's going on here.
If you're replacing cheap garbage Ebay springs they might go bad, but not OEM spring steel or a quality spring manufacturer.
Old 08-26-2011, 08:23 AM
I'm replacing the oem struts ...and assume the springs are aswell .
I found apx struts online a full set of 4 for 140 $ should I buy these ?
Old 08-27-2011, 08:29 PM
smooshies's Avatar
At the very least, get Monroes. For decent shocks, a lot of people like Tokicos, and KYBs. For good shocks, do Konis or Bilsteins, but expect to pay a lot more.
This line is almost a cliche around here, but I'll say it anyways: Don't try to save money on suspension parts! You get what you pay for. I know this first hand. The first set of shocks I bought for my 2000 Honda Civic were Sensen off Ebay for $140. They rode like crap, handled unpredictably, and probably would not have lasted long. So, I saved up some money and got Koni Yellows, which are fantastic. Unless you drive 20 miles per hour always, you don't want to mess with cheap shocks. If you have to swerve on the freeway, you just can't trust a 35 dollar shock.
Save up and get something that you can trust.
Old 08-27-2011, 08:33 PM
Master Detailer
98civdx's Avatar
NO! A quality shock (koni) will set you back that much for one. Hell even skunk2 shocks cost $300
if your staying OEM just go get a set of Monroe's. If you are modify, tell us your plans/budget and we can reccomend a setup.
Oh and these car's run SHOCKS, not struts.
andytay83
Suspension & Brakes
03-30-2012 02:22 AM
KYLE.ECKERT
Suspension & Brakes
07-26-2008 09:53 PM
Fook_me_honda
12-18-2006 01:15 PM
DiPPeD iN miLk Ej CoUpE
06-29-2003 11:42 AM
Quick Reply: strut spring question
