Stripped top hat allen hole???? What to do now?
Old 04-24-2004, 10:24 PM
Spence's Avatar
Default Stripped top hat allen hole???? What to do now?
Well i tried to get the top of the strut tower off and i ended up stripping the allen wrench hole the ******* bolt was really rusted on i tried using some pb blaster before and and this bitch stripped out any help
Old 04-24-2004, 10:28 PM
func-tion's Avatar
Default Re: Stripped top hat allen hole???? What to do now? (Spence)
Get the next size up allen wrench and beat it in there. Or get another shock.
Old 04-24-2004, 10:38 PM
Spence's Avatar
Well i really dont need the shock i just need to get the top hat off so i can put the my new suspesion on
Old 04-24-2004, 10:55 PM
dfoxengr's Avatar
Default Re: Stripped top hat allen hole???? What to do now? (func-tion)
just use air tools. you dont need the allen with them.
Old 04-24-2004, 10:57 PM
func-tion's Avatar
Default Re: Stripped top hat allen hole???? What to do now? (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">just use air tools. you dont need the allen with them.</TD></TR></TABLE>
and if you dont have access to them and your planning on tossing the shocks clamp vice grips to the shock shaft.
Old 04-24-2004, 11:05 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by func-tion &raquo;</TD></TR><TR><TD CLASS="quote">
and if you dont have access to them and your planning on tossing the shocks clamp vice grips to the shock shaft.</TD></TR></TABLE>
bad idea, will scar the strut rods and may cause leaks
Old 04-25-2004, 12:03 AM
STIBungy's Avatar
he said he doesnt need the struts anymore.
Old 04-25-2004, 12:14 AM
eL
eL's Avatar
Works like a charm, I've done it before ...when we werent keeping the oem shocks.
Old 04-25-2004, 12:40 AM
tominos's Avatar
what did you do man? haha
worse case scenario, weld a piece of metal onto the rod if possible and use it to hold it.
Old 04-25-2004, 12:42 AM
elwood's Avatar
You could cut the nut off with a hacksaw.
Old 04-25-2004, 01:50 AM
STREETWERKZ's Avatar
Default Re: Stripped top hat allen hole???? What to do now? (elwood)
sears sells craftsman 'screw out' and 'nut out'
sounds corny, but you cant go wrong with these.
worth the money, but you wont use it that often, but when you do come across a stripped screw or nut, it's a friggan life saver.
Old 04-25-2004, 06:49 AM
Mr.E.G.'s Avatar
use a dremel to cut a slice across the top and take it out with a slotted screw driver
Old 04-25-2004, 07:58 AM
fishnfst's Avatar
Vice grips are the easiest if you are going to toss the shocks. I'm sorry, actually a $20 electric impact gun from sears is the easiest way to remove the nut vice grips are second.
Old 04-25-2004, 08:59 AM
dfoxengr's Avatar
Default Re: (fishnfst)
yeah i would cut it off. ive had to do that before
Old 04-25-2004, 10:22 AM
elwood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote">Vice grips are the easiest if you are going to toss the shocks. I'm sorry, actually a $20 electric impact gun from sears is the easiest way to remove the nut vice grips are second.</TD></TR></TABLE>
You cant get at the strut shaft when the dust cover is still on, and
you cant get that off untill you remove the tophat.
"use a dremel to cut a slice across the top and take it out with a slotted screw driver"
Ive tried that, dosnt work, it will just bend the two peices off and your stuck with
an even shorter allen hole.
Seriously, the only thing that I would be 100% sure that will work is go and
get some nice air tools, or take them to a machine shop and have them
bust it off. I really dont think that an electric impact gun will do it. I have
never used one, but anything that only costs "20$", I wouldnt think has
much power.
kixcrx
12-12-2006 08:35 PM
.water
Welding / Fabrication
24
11-08-2005 08:50 PM
4drsedaneg
Suspension & Brakes
02-25-2005 10:01 AM
ch4nq
53
02-09-2005 02:36 PM
k279
04-16-2004 06:15 AM
Quick Reply: Stripped top hat allen hole???? What to do now?
