Problems with EG headlights????
For some reason about a week ago on my low beams when i was driving home the passenger side started to flicker then it shut off. So i turned my low beams off and put my brights on it worked like always, when i got home i clicked the low beams back on and the bulb works again.....this has been happening for like a week now it just shuts off and comes back on.
Now lastnight i was in the left turning lane with my turn signal on, and it started clicking fast like one of my bulbs wernt working. After i looked at it the from turn signal did not work that whole night. The next day it works like nothing was ever wrong. Im ****ing confused on this and i need some help. Please any suggestions helps.
Re: Problems with EG headlights????
I would check your headlight connections, these EG's are only getting older and one of those plastic clips could have snapped. happened on mine
Thats true, i check the connections when it first started everything looked good. The bulbs are brand new, they look good...The only thing that makes it weird is the fact that when i have my hids hooked up the bulb always blows no longer than 6months later and it blows on the same side that it flickers with the stock bulb in.
Freakin weird man
Freakin weird man
Okay, so i checked the grounds from both diagrams you gave me, nothing was **** up...Its confusing me
same thing happened to mine. i just diconnected the headlight connection and blew into it and it stopped. just like blowing into a super nintendo game to make it work haha works all the time
if your grounds are fine, check your plugs that plug into your headlight, i had one that was slightly cracked, and it would cause the plug to not make contact with the prongs when i went over bumps, i'm pretty sure i have a couple extra plugs if you need
biscuitjones
11-06-2006 09:43 PM
granturismonut2
09-09-2006 07:55 AM
