Stripped oil plug. - Honda-Tech
Stripped oil plug.
Old 05-14-2005, 05:58 PM   #1
Slipjack's Avatar
Default Stripped oil plug.
I just bought a '93 Civic HB and when I bought it home to give it an oil change I found that the oil plug is stripped out. I might be able to unscrew it if I try hard enough, I just wanted to know if anybody knew any tricks that I don't know about to get it off.
Slipjack is offline   Reply With Quote
Old 05-14-2005, 06:00 PM   #2
Lmgrcivic's Avatar
Default Re: Stripped oil plug. (Slipjack)
weld something to it and unscrew it and get a new one
Lmgrcivic is offline   Reply With Quote
Old 05-14-2005, 06:00 PM   #3
Slipjack's Avatar
Default Re: Stripped oil plug. (Lmgrcivic)
Not bad, will need to drive it to my Dad's for a welder. Any other ideas before I go do that instead?
Old 05-14-2005, 06:12 PM   #4
Electrician
Deemeetree's Avatar
Get a grinder, knotch a groove in the center, get your biggest/heaviest flathead, try from there. You can try Vise-Grips.
Deemeetree is offline   Reply With Quote
Old 05-14-2005, 06:18 PM   #5
Slipjack's Avatar
Default Re: (Dimitri_EG8)
That'll work. Thanks. Tried the vicegrips. They just slipped around on the plug like the wrench did. Someone did a real number on it, multiple times.
If whoever did this was stupid enough to not only strip the oil drain plug, but to keep using it and stripping it more and more each time -- now I have to look at every single facet of this car to see what other stupid crap might have been done to it.
Old 05-14-2005, 07:00 PM   #6
Hurricane's Avatar
Default Re: (Slipjack)
Worst case senario, you have to pull the oil pan while its full ($#@%$#@mess) and replace it with one that has a good plug.
Hurricane is offline   Reply With Quote
Old 05-14-2005, 07:41 PM   #7
extra cam needed's Avatar
Location: americas finest, calee fourn ya, united states
Use a plumber's pipe wrench
extra cam needed is offline   Reply With Quote
Old 05-14-2005, 08:09 PM   #8
TurboTagTeam's Avatar
Default Re: (extra cam needed)
Quote:
Or use a dremal or something
TurboTagTeam is offline   Reply With Quote
Old 05-14-2005, 08:10 PM   #9
SOHC4life 96's Avatar
You could get a socket that is smaller than the plug bolt right now and hammer it on there and then see if that works. The socket should be expendable though.
SOHC4life 96 is offline   Reply With Quote
Old 05-14-2005, 09:43 PM   #10
H-T White Ops
Frozen E's Avatar
Pick one up at your local hardware store. $4-10 TOPS.
Frozen E is offline   Reply With Quote
Old 05-15-2005, 08:33 AM   #11
get a strip bolt remover from Sears. It is like $20. Make sure you buy the metric version.
worked for my stripped bolted on the CAT.
Good Luck
tuphatt is offline   Reply With Quote
Old 05-15-2005, 09:33 AM   #12
00supercivic's Avatar
yeah i would try the pipe wrench casue i had the same problem, and it came of in the first try. or if you have to you might have to get a bolt extractor form auto zone. and as far as gettin a new one you can get it from honda with a new crush washer for like 4 bucks, thats what i did. good luck
00supercivic is offline   Reply With Quote
Old 05-15-2005, 10:00 AM   #13
peiku's Avatar
Default Re: Stripped oil plug. (tuphatt)
Good Luck
i would suggest this too. i bought a set and have never regretted it. i have taken out many stripped bolts.
peiku is offline   Reply With Quote
Old 05-15-2005, 10:34 AM   #14
nocturnaldragon's Avatar
Those things are pure ****. Get a pipe wrench.
nocturnaldragon is offline   Reply With Quote
Old 05-15-2005, 10:45 AM   #15
T4eg's Avatar
Default Re: Stripped oil plug. (nocturnaldragon)
I just ran into the same problem. I took the pan off and drilled out the hole and welded a 3/8" pipe fititng in. (flush with inside pan) then using a 3/8 pipe plug as a drain plug
T4eg is offline   Reply With Quote
Old 05-15-2005, 03:02 PM   #16
Default Re: Stripped oil plug. (T4eg)
pipe wrench should work. just be sure to have a replacement plug on hand when you finally get the stripped one ut.
kkim is offline   Reply With Quote
Moroso oil pan drain plug is stripped, tap it bigger? Better option? KevinEF7 Forced Induction 24 03-02-2013 08:19 AM
90 integra gs TPS red wire no voltage? XSIntegra Acura Integra 1 05-04-2012 10:34 AM
Stripped Oil Pan Wimpy. Honda Motorcycles 11 10-26-2005 10:00 AM
Stripped out oil pan...please help epibone Acura Integra 14 03-21-2004 04:36 PM
Windshield rubber stripping 555R Honda Civic / Del Sol (1992 - 2000) 2 06-29-2002 02:30 PM
Tags
2006, civic, eb3, grinder, honda, oil, plg, plug, stripped, toyota, tricks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
