hks turbo timer 1 in eg need help...
Old 05-14-2005, 01:32 PM
NYCFINESTEG's Avatar
Default hks turbo timer 1 in eg need help...
ok guys i just installed the turbo timer in my eg and when i **** off the car the car shuts off but the timer counts down, please help i just went over the wiring 3 times and yes the parking brake is up
Old 05-14-2005, 03:10 PM
ham
ham's Avatar
Default Re: hks turbo timer 1 in eg need help... (NYCFINESTEG)
how do you have it wired? are the main3 wires going to the main relay, then a ground + ebrake wire?
i had to tap into my fusebox for a constant, i didnt have one on the main relay. its probably the constant giving you problems.
Old 05-14-2005, 05:27 PM
Default Re: hks turbo timer 1 in eg need help... (ham)
i have the red to constant it's a white wire and the green to 12 ign yellow and black i think and the other one to accessory,, everything works but when i shut the car off it shuts off and the timer counts down lol i tried switching 12v ign and constant but than it didnt count down so i guess i have something on wrong lol i'm confused did anybody have this problem?????? maybe the turbo timer is broken i did buy it used??? help guys lol
Old 05-14-2005, 05:31 PM
oo and i used the brake wire on top of the pedel instead of the e-brake wire,,, i even switched to the e-brake wire and it didnt count down so i guess u gotta use the brake pedel wire.... i tried to troubleshoot and i'm at a dead end, i also was thinking it was in some program mode so i reset it and still count down wit the car off lol helppp,,,,
Old 05-14-2005, 07:18 PM
ham
ham's Avatar
get your voltmeter out and make sure the wires are right. i bet your constant really isnt a constant. i had the same problem. the turbo timer takes the constant and switches it over to the accesory to keep the engine running. but when there is no constant, it cant do anything.
Old 05-14-2005, 08:27 PM
TeamNextGenChris's Avatar
are you sure you have the proper ignition wires?
Chris
Old 05-14-2005, 08:50 PM
Default Re: hks turbo timer 1 in eg need help... (TeamNextGenChris)
yes i hooked the red to the white for constant and the green to black yellow 92 civic ign and constant wires
Old 05-14-2005, 08:51 PM
well there is a yellow and i'm kinda thinking that the constant so i'm gonna check tommorrow cause the timer works fine just car dont stay on so i'm gonna check it tommorrow any other ideas guys please tell me???
Old 05-15-2005, 08:20 AM
OK GUYS THE YELLOW IS IGN 2 NOT A CONSTANT OK THIS HOW I WIRED IT
RED 12 VOLT CONSTANT- TO WHITE WIRE IGN HARNESS
GREEN 12V IGN- BLACK/ YELLOW
BLUE 12V ACC- WHITE/BLACK
BLACK- GROUND- TO A GROUND BY THE DRIVERS DOOR
GRAY PARK WIRE- ABOVE BRAKE PEDEL GREEN/WHITE
BROWN RPM- BLUE WIRE AT DIST CHECKED AT WORKS
BLUE- SPEED SENSOR- TO B10 ON MY B PLUG/LIL PLUG MIDDLE CHECKED FOR SPEED ON TIMER AND IT WORKS
OK THIS THE PROBLEM ALL THE MODES WORK BUT WHEN I TURN THE KEY OFF THE CAR SHUTS OFF BUT THE TIMER COUNTS DOWN??? U GUYS SAID IT WAS THE CONSTANT BUT THE CONSTANT WHITE WIRE GOTTA BE RIGHT CAUSE WHEN I TAKE THE KEY OUT THE TIMER STILL COUNTS DOWN SO IT GOTTA BE HOOKED UP TO CONSTANT TO STAY ON SO NOW I'M CONFUSED...I'M THINKING THE TIMER IS BROKEN CAUSE EVERYTHING IS HOOKED UP RIGHT PLEASE ANY IDEAS LOL
Old 05-15-2005, 10:07 AM
mokocivic97's Avatar
i have the same turbo timer for my ek. the type one. i cant get mine to work rite..
Old 05-15-2005, 02:07 PM
ham
ham's Avatar
take the red wire and run it to the + on the battery and see if it works.
skyman88
07-19-2004 11:32 AM
MattGSR
05-26-2004 08:20 PM
japspec
10-26-2003 01:14 AM
B_1_8_hatch
08-07-2003 02:10 PM
B18EG6
08-17-2002 03:53 PM
Quick Reply: hks turbo timer 1 in eg need help...
