Stock GSR D brackets on ASR question!?!
Old 11-22-2010, 04:21 PM
delsolo95's Avatar
Icon2 Stock GSR D brackets on ASR question!?!
Quick question guys and gals. Does anyone know if Im suppose to get the asr d brackets for the asr brace? Cuz my stock gsr d brackets are short and doesn't line up to the holes on the asr brace. Or am I suppose to go with a larger sway bar? Tia!
btw im trying to use the stock swaybar and d brackets!
Old 11-22-2010, 05:26 PM
batallic's Avatar
Default Re: Stock GSR D brackets on ASR question!?!
u dont need a subframe brace anyways, if yur using a GSR sway bar
Old 11-22-2010, 06:33 PM
Master Detailer
98civdx's Avatar
You "should" be runing a larger sway bar with a asr brace, other wise they are basicly pointless..
However you can buy adjustable D brackets for just this, or may be able to modify your current D brackets.
Old 11-22-2010, 06:35 PM
delsolo95's Avatar
I got it for bling. Anyways anyone know if I have to get the asr d brackets? cuz the two holes on the d brackets don't match the asr brace.
Old 11-22-2010, 06:38 PM
delsolo95's Avatar
If I modify the d brackets that would gap the bushings to the bracket.
**what size swaybar are you guys running with you asr brace?
Master Detailer
98civdx's Avatar
You cant enlarge the holes on the bracket to match??
Energy suspension sells them i think for around 30 bucks, Look at it, youll see what i mean,
Old 11-22-2010, 06:47 PM
delsolo95's Avatar
Lemme take a pic I'll be right back. Iono if what Im saying is understandable. Brb
Old 11-22-2010, 07:05 PM
4everjdm's Avatar
Thats weird if the holes dont line up on your D brackets, since the holes on the ASR brace should lines up on your car. I just installed a ASR brace on my Ej1 w/ the ASR Sway bar and it lined up great. If your doing it for the bling you should get the ASR sway bar & the D brackets, they look mighty fine when its all put together.
Old 11-22-2010, 07:07 PM
delsolo95's Avatar
i dont have an asr swaybar. im trying to use the stock swaybar and brackets. but if it dont work then....
Old 11-22-2010, 07:25 PM
4everjdm's Avatar
It doesn't make sense that those D brackets bolt on to the car w/ no problem before & the ASR brace uses the same holes and it doesn't match up.
Old 11-22-2010, 08:02 PM
delsolo95's Avatar
So ok.. There's three bolt on the right, the top one and middle one is where the stock swaybar bracket bolts to. Im thinking your suppose to use the top and third bolt in pic for sway bar d bracket am I right?
[/QUOTE]
Old 11-22-2010, 08:04 PM
Master Detailer
98civdx's Avatar
The reason why is asr's are set up for 22mm+ sway bars which use larger d brackets.
Hence the smaller ones won't work without being moded.
Are you sure its a real asr?
You may need the adjustable ones I said.
Old 11-22-2010, 08:09 PM
delsolo95's Avatar
It actually does. But the middle bolt groove into the brace therefore I cannot use that. IIm suppose to use the top and bottom bolt for the d brackets correct?
Old 11-22-2010, 08:15 PM
delsolo95's Avatar
Yes Im 110% sure it's a real asr. Geez why didn't they ( asr ) say you have get larger d brackets and swaybar.... the shop I got it from said I could use my stock d brackets...Effin liar!!! Fml Ill just get a new sway bar thanks for your replies and help!
Old 11-22-2010, 08:20 PM
Master Detailer
98civdx's Avatar
Did you look at the d brackets I mentiond?
30 beats a 200+ sway bar.
Old 11-22-2010, 08:50 PM
4everjdm's Avatar
Yes correct, My sway bar used the top and bottom bolt on the brace and mounted right over the middle bolt.
Old 11-22-2010, 09:04 PM
em1effekt's Avatar
i used the stock ones but the bolt pattern for the civics is different...
i would try to customize the stock brackets..if not get the 30 dollar ones..
Old 11-22-2010, 09:54 PM
delsolo95's Avatar
Couldn't find it at the energy suspension website. All I see for my make and model are a bunch of bushings and ball joints.
direct Website could help me though!!! Thanks
Old 11-23-2010, 04:22 AM
rhymeshark916's Avatar
Type R sway bar is $100 or less. I think I bough mines for $80. Why not upgrade to a thicker/better bar in conjunction with the ASR?
Old 11-23-2010, 12:19 PM
Master Detailer
98civdx's Avatar
That's true, however, some buy ASR sway bars which are more then $100
A larger rear sway bar will casue more oversteer, which some people dont like, and it can get you into trouble fast.
Ill see if i can find it
Old 11-23-2010, 12:22 PM
Master Detailer
98civdx's Avatar
http://www.energysuspensionparts.com...sp?prod=9.5153
Might work, dont quote me on it though.
Old 11-23-2010, 02:51 PM
delsolo95's Avatar
thanks 98civdx!
Old 11-23-2010, 03:07 PM
Master Detailer
98civdx's Avatar
No Problem hope it works
BoostKiller
Northwest (Sales)
11-01-2008 12:42 AM
weak_tec
Suspension & Brakes
05-25-2006 08:47 AM
cu_jarrett
Suspension & Brakes
02-09-2005 09:07 AM
Chris1091
04-18-2004 08:47 AM
LethalX
10-16-2001 07:14 AM
Quick Reply: Stock GSR D brackets on ASR question!?!
