Steering wheel squeaks loudly when turning left... - Honda-Tech
Old 12-18-2005, 06:15 PM   #1
transpar_nt's Avatar
Default Steering wheel squeaks loudly when turning left...
I've got a 92 eg8 and my steering wheels squeeks pretty loudly whenever I turn left. It ONLY happens when I turn left, and it ALWAYS happens when its cold outside. In the middle of the summer I don't really notice it, so if its happening then its a lot quieter. It isn't any harder to turn than usual and I've noticed no other problems with it, but its really annoying and embarrasing if I have passengers in the car. Anyone know what this could be?
EDIT: For clarification, the sound is coming from behind the steering wheels somewhere. There is nothing wrong with the suspension/tierods or anything, and it can only be heard inside the cab.
Modified by transpar_nt at 8:30 PM 12/18/2005
transpar_nt is offline   Reply With Quote
Old 12-18-2005, 06:24 PM   #2
RIP 1032
life sux die's Avatar
Default Re: Steering wheel squeaks loudly when turning left... (transpar_nt)
check all your boots in the suspension (axels, steering rack, etc...) also, check your steering column maybe it needs to be greased up a bit?
life sux die is offline   Reply With Quote
Old 12-18-2005, 06:33 PM   #3
Default Re: Steering wheel squeaks loudly when turning left... (life sux die)
The thing I can't figure out is why it only happens when turning left. If it needed greasing, wouldn't it make sound both ways?
Old 12-18-2005, 06:50 PM   #4
inline4's Avatar
with the key all the way to the on position(this will release the steering lock)
have a friend turn the steering wheel left while you stick your head under the wheel and see where the noise is coming from.
i had a loose bolt under there before, can't remember if it made any noise, but it was just loose, and I think it was somehow attached to a spring on the steering rack.
that could be your problem, that spring might be compressing and decompressing when you turn left.
inline4 is offline   Reply With Quote
Old 12-18-2005, 07:04 PM   #5
old man neri's Avatar
sounds like a power steering issue, either the pump or the rack..........
old man neri is offline   Reply With Quote
B18 in EG ==> hood hits valve cover transpar_nt Hybrid / Engine Swaps 40 03-08-2016 07:22 PM
Can't remove sun visors. Bolts seem threadlocked. transpar_nt Honda Civic / Del Sol (1992 - 2000) 6 08-11-2005 02:17 PM
Will this swaybar work on my car? transpar_nt Honda Civic / Del Sol (1992 - 2000) 4 08-08-2005 04:53 PM
Nice surprise!!! transpar_nt General Discussion and Debate 6 08-08-2005 09:19 AM
Who likes polls? transpar_nt General Discussion and Debate 10 08-01-2005 08:23 AM
Tags
car, del, honda, left, power, rack, sol, sqeaks, squeakes, squeaks, squeals, squeeks, steering, steery, turn, turning, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
