Steering Wheel Squeaks
Old 05-22-2011, 04:04 PM
KingDakota12's Avatar
Default Steering Wheel Squeaks
It seems at a stop only not when Im driving if I move my steering wheel a loud squealing and squeaking comes from under both of my tires? Is that the steering column maybe?
It doesn't seem like the steering column, but instead the front suspension. I know my front control arm bushings are bad, but I doubt it has much to do with that.
Old 05-22-2011, 04:17 PM
The Grumpiest
grumblemarc's Avatar
Default Re: Steering Wheel Squeaks
So which is it? Steering wheel? Tires? Or suspension? Have you had someone look/listen while someone turned the wheel?
Old 05-22-2011, 04:19 PM
I did. The main squeak doesn't come from steering wheel or column, but under the car around tires and front control arms.
Old 05-22-2011, 05:56 PM
Mr2Rotor's Avatar
Just had that it was a ball joint thing is you have to determine which side has the bad lower ball joint. If you want to be safe just replace both sides
Old 05-22-2011, 06:33 PM
Hmmm is there anyway to figure out if it is by ball joints before I replace them?
lxdriver
12-07-2011 06:10 AM
lildragon'07
13
06-02-2010 08:31 AM
buzlink
18
11-07-2006 07:04 AM
fourdoorteg
Suspension & Brakes
05-28-2005 10:24 PM
Quick Reply: Steering Wheel Squeaks
