Steering wheel shake at high speed?????? - Honda-Tech
Old 01-03-2011, 09:59 AM   #1
Default Steering wheel shake at high speed??????
Hello guys, I have a problem with my 99 civic EX. The past couple of weeks ago my civic steering wheel started to shake when you hit high speed (70 mph). From 0-65 mph the steering wheel does not shake whatsoever but when you hit 70 mph and on the steering wheel shake so much. I have rotor and balance my tires but it did not fixed the problem the shaking is still there. I don't know what is causing it to shake. Can anyone please give me some advices, I really appreciate it. Thanks
black94lude is offline   Reply With Quote
Old 01-03-2011, 10:09 AM   #2
The Grumpiest
grumblemarc's Avatar
Default Re: Steering wheel shake at high speed??????
Strut/bushings bad? Is it coming from a particular side?
grumblemarc is offline   Reply With Quote
Old 01-03-2011, 10:38 AM   #3
I don't know exactly what side it is coming from. I can't really tell whether is coming from the passenger side or the driver side because when you hit 70 mph the only thing you notice is that the steering wheel shake only. So I can't really tell. Do you think could it be an axle is bad????? Thanks
Old 01-03-2011, 11:50 AM   #4
habib's Avatar
Quote:
Originally Posted by grumblemarc View Post
Strut/bushings bad?
This or a bad axle
habib is offline   Reply With Quote
Old 01-03-2011, 12:57 PM   #5
Can a bad axle cause the steering wheel to shake at high speed (70 mph)...???
Old 01-03-2011, 01:41 PM   #6
mattliston's Avatar
yes a worn though usable axle can vibrate at higehr speeds.
othing to worry about if its the axle.
the steering wheel shaking though, it probably is either an unbalanced tire or tie rods are going badd.
a rarety is the rack and pinion bushing so bad it magnifies the vibration at 70+mph
mattliston is offline   Reply With Quote
Old 01-03-2011, 02:08 PM   #7
Oh thanks. I take the car to have the tires rotor and balance tomorrow and I get back to let you guys know to see if it solve the problem. If not I try something else. Dang this problem is driving me nuts.....But once Thanks I really appreciate all you guys help.....
Old 01-03-2011, 02:19 PM   #8
EkLanta's Avatar
You should also get the car alighted, might be that your car is unaligned and the wheels are fighting each other to stay straight. If that makes scene to you.
EkLanta is offline   Reply With Quote
Old 01-03-2011, 02:23 PM   #9
This happened to a family member though it was more like 50mph+, after struts is was fine (not even an alignment).
thbx59 is offline   Reply With Quote
Old 01-03-2011, 02:40 PM   #10
Tie rods are my guess.
blowededup is offline   Reply With Quote
Old 01-03-2011, 02:43 PM   #11
Thanks guys for the advices and information.......I really appreciate it....
Old 01-03-2011, 03:31 PM   #12
or if you just moved to a snowy area, snow will do this.
otherwise go over whats been stated.
Red_Army is offline   Reply With Quote
Old 01-03-2011, 04:05 PM   #13
blackoutt2000's Avatar
I just picked up a 99 ex coupe that does this too, right around 70mph the wheel will start to shake for a couple seconds, smooth for a couple seconds, then shake for a couple seconds ....
I haven't done anything to it but there was a receipt in the glovebox for a new control arm and alignment recently, and it just passed NYS inspection so I'm guessing the tie rod ends and brakes are fine. My guess is out of balance or bent wheel, or an axle maybe? Are they hard to change?
blackoutt2000 is offline   Reply With Quote
Old 01-04-2011, 07:03 AM   #14
Changing a axle is not a problem for me. It not that hard to change the axle.........
Old 01-04-2011, 04:31 PM   #15
slayerfromhell212's Avatar
most of time its a wheel bearing check that out 70+ for sure its wheel bearing
slayerfromhell212 is offline   Reply With Quote
Old 01-04-2011, 04:42 PM   #16
XYRS2LT's Avatar
I have seen warped rotors do this, a bent wheel, or the aformentioned suspension parts. Get your rotors turned, if that does not cure it try rotating your tires front to back, then test drive it again. Also, have seen a seperated tire do this as well. Try these and let us know what the problem is.
XYRS2LT is offline   Reply With Quote
Old 08-01-2013, 11:17 AM   #17
try removing your brake rotors and see if the problem persists, lol IM KIDDING!
my car has this issue and here is the list of what a mechanic told me is wrong, upper right front control arm, most of my bushings, and a ball joint (lower right front) most of this likely caused because i drive it like i stole it lol
f1jedi is offline   Reply With Quote
Old 08-01-2013, 11:19 AM   #18
The Grumpiest
Nice story. Let's hope he figured it out by now.
Old 08-01-2013, 11:38 AM   #19
Quote:
By separated tire do you mean one that falls off?!
crazyhouse2011 is offline   Reply With Quote
Old 08-01-2013, 11:40 AM   #20
The Grumpiest
Couldn't Google this before you asked such an obvious question?
It's where the tread separates from the belt/rest of tire.
You don't know a lot about cars at all do you?
Old 08-01-2013, 11:47 AM   #21
Ugh.... this guy.... ^
Old 08-01-2013, 11:51 AM   #22
The Grumpiest
Yeah. If I were you, I'd hate me too. Try educating yourself before asking simple questions.
Old 08-01-2013, 01:43 PM   #23
strategy400's Avatar
We call those alligators because they jump up and bite the side of your car.
strategy400 is offline   Reply With Quote
brake pedal and steering wheel shake choua01 Honda Civic (2006 - 2015) 2 06-20-2012 12:43 PM
Shaking on the Front Wheel? DAP97SI Honda Civic / Del Sol (1992 - 2000) 12 06-04-2007 02:51 PM
steering wheel vibration boots420 Honda Civic / Del Sol (1992 - 2000) 5 05-09-2007 09:57 PM
Steering wheel shakes at idle and high speed Junkyard2000 Honda CRX / EF Civic (1988 - 1991) 4 12-20-2005 11:14 AM
My brake is weird..? blklude Honda Prelude 8 06-27-2003 07:30 AM
Tags
70, 90, 99, civic, high, hit, honda, shake, shakes, snow, speed, speeds, steering, unaligned, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
