steering help
Old 06-19-2012, 06:30 PM
swizz977's Avatar
Default steering help
ok so my steering was pretty bad my wheel wasnt centering
i was hearing cracking sounds (which still make noise even after new rack ) when i would jerk wheel or go from a stop..
put it on the lift.. saw my steering rack was leaking power steering fluid..
just changed it the power steering rack with tie rods inner and outter and now its even worse..
the wheel feels very stiff and when i put it any which way evn like an inch over while im driving and let go it will just stay there..
everything under the car was fine like ball joints but not 100% just pushed up and down on wherl had no play.. also have after market upper camber kit
the only thing i can think of is a bad power steering pump.. would this cause this if its bad?
also the wheel turns to the right easy but to the left very hard..
oh and i got an alignment right after
i hope the new rack isnt bad
i mean how would i know if my ball joints are siezed? they didnt really have any play
Old 06-19-2012, 09:02 PM
swizz977's Avatar
Default Re: steering help
helpppppppp
Old 06-20-2012, 04:53 AM
swizz977's Avatar
anyone????
Old 06-20-2012, 06:38 AM
R.I.P. Mark
MRGRIM's Avatar
if it is the pump..simple test
with the motor off turn the wheel hard
while holding it start the car
if it goes soft the pump is working
doesnt mean its good but does show its pumping at least
but how much diffrence is there between turning the wheel with engine off and engine on
if there only a little diffrence then sounds like a pump or blockage or low fluid
Old 06-20-2012, 06:49 AM
swizz977's Avatar
well when i turn it to the right its easy but to the left its hard
Old 06-20-2012, 07:13 AM
R.I.P. Mark
MRGRIM's Avatar
could be the control valve in the steering rack
another test you could do is
disconnect the tierods at the knuckle and then see if the stiffness is still there if it is then steering rack ( test with and with out engine running )
if its stiffness is gone then start looking at the upper and lower joints
Old 06-20-2012, 08:16 AM
swizz977's Avatar
great just paid 200 for rack n 200 for labor for a bad rack man autozone sucks
Old 06-20-2012, 09:37 AM
swizz977's Avatar
i have the worst luck they gave me a bad alternatir too.. if i change the ball joints and it still is like this its probally a bad rack correct? because the power steering does work not that good but it wouldnt be hard to move it left but not right correct?
Old 06-20-2012, 09:46 AM
swizz977's Avatar
my mechanic said this just now about my ball joints If they were it would have been hard to turn the spindle when there was no rack in the car. They moved fine. is that true?
Old 06-20-2012, 03:56 PM
swizz977's Avatar
gona try a new power steering pump just got tomorow
Old 06-20-2012, 07:28 PM
R.I.P. Mark
MRGRIM's Avatar
yes that is true
basicly what i said above re testing with the rack disconnected
Old 06-20-2012, 07:51 PM
swizz977's Avatar
so wtf its a bad rack i mean.. is autozone going to pay me for the labor on a bad rack wtf
Old 06-20-2012, 09:21 PM
jbpnoman's Avatar
Of course they aren't. If you wanted labor covered, you should have bought the part through the shop. Save a dime, spend a dollar.
Old 06-21-2012, 05:39 AM
swizz977's Avatar
its my buddy im not goin to some shop
Old 06-21-2012, 05:55 AM
swizz977's Avatar
maby wheel bearings or axles or steering column shaft i kno that has play
Old 06-21-2012, 06:24 AM
swizz977's Avatar
maby even lca bushing
Old 06-21-2012, 02:49 PM
swizz977's Avatar
bumpppppppp
Old 06-21-2012, 02:55 PM
The Grumpiest
grumblemarc's Avatar
Replace all of it. You aren't doing any troubleshooting. Just guessing.
Old 06-21-2012, 03:36 PM
swizz977's Avatar
thats why im asking for help
Old 06-21-2012, 03:43 PM
The Grumpiest
And you're not taking anyone's advice either.
Old 06-21-2012, 03:53 PM
swizz977's Avatar
is that plural because mr grim is the only one who gave advice
Old 06-21-2012, 03:56 PM
The Grumpiest
And you're not taking it. Just sitting there scratching your head looking confused.
Did you check the ball joints? I'm sorry. Did your FRIEND check the ball joints?
I found this just in case neither of you know how.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-check-ball-joints-2526095/
Old 06-21-2012, 04:44 PM
swizz977's Avatar
Old 06-21-2012, 04:51 PM
The Grumpiest
If you have a mechanic working on it I don't understand why you're posting for help in a forum. How are YOU performing the troubleshooting?
Old 06-21-2012, 05:22 PM
swizz977's Avatar
by making this thread need some more opinions
noahs_ark
Honda Civic (2006 - 2015)
09-12-2016 05:25 PM
White_EG1
23
04-12-2016 08:34 PM
Ventolin
05-14-2008 11:45 AM
TurboBumblBee
19
08-18-2003 10:29 AM
mr_mbuna
09-04-2002 08:43 PM
Quick Reply: steering help
