Starting car with wrong firing order cause damage? - Honda-Tech
Old 03-15-2003, 03:52 PM   #1
Qwikrex's Avatar
Default Starting car with wrong firing order cause damage?
The guy who was working on my car didnt know the exact firing order and mixed up the wires. He tried to start the car several times and it sputtered and died. A couple times, the car backfired. When he finally got it right, the car started and ran normally. Could this have caused any damage?
Qwikrex is offline   Reply With Quote
Old 03-15-2003, 03:54 PM   #2
Default Re: Starting car with wrong firing order cause damage? ([VTEC]TL)
You're fine.
Just look it up and do it right
NiiS is offline   Reply With Quote
Old 03-15-2003, 03:58 PM   #3
IdotheSHOCKER's Avatar
been there, done that, no biggie....
IdotheSHOCKER is offline   Reply With Quote
Old 03-15-2003, 04:01 PM   #4
Qwikrex's Avatar
Default Re: Starting car with wrong firing order cause damage? (sinister)
Ok, thanks. Because I was figuring that if the distributor was sparking in the wrong order, it would spark on the wrong upstroke/downstroke, and the back fires I heard was detonation. A hole in a piston or a bent valve is never good. So you think I should be ok? Because my car felt a tad sluggish, but it's probably all in my head. Everytime I get paranoid about something happening to my car, it always feels slower
Old 03-15-2003, 05:48 PM   #5
Qwikrex's Avatar
Another thing, while trying to start the car, he gave it a little bit of gas to see if it would start, not knowing the right firing order. Would this hurt anything? Please bear with my paranoia
Old 03-15-2003, 07:13 PM   #6
Zeus Zore's Avatar
you clear... he should have done some research before doing it..
but i have run my motor and driving it with the plugs in the wrong holes.. and i have been running it on 2 cyl as well.. sounds kinda sweet.. but ran fin..
Zeus Zore is offline   Reply With Quote
Old 03-15-2003, 08:11 PM   #7
Happyman's Avatar
Default Re: Starting car with wrong firing order cause damage? (Zeus Zore)
No you havn't. A 4 cyl. motor will not run on 2 cyl. It probably won't even run on 3.
Happyman is offline   Reply With Quote
Old 03-16-2003, 01:25 AM   #8
Zeus Zore's Avatar
Default Re: Starting car with wrong firing order cause damage? (Happyman)
Well it did !!.. and it actualy was not that bad.. sounded kinda funny but it startet right up.. so a 4 cyl will be abel 2 do it !!.. and it would run with 3 cyl as well...
the only brop is that it is not at the same balance as it is with all 4 running..
Old 03-16-2003, 03:16 AM   #9
mixmastabob's Avatar
Yea, he's right... my friends old *** Golf runs all 3 cylinders allll day long
mixmastabob is offline   Reply With Quote
Old 03-16-2003, 10:29 AM   #10
Qwikrex's Avatar
Default Re: Starting car with wrong firing order cause damage? (mixmastabob)
Alright,so the general consensus is that wrong firing order will not cause damage. Oh, just a word of advice, Magnacore wires suck ***! The reason the guy kept on changing the firing order around was because when I installed the magnacores on correctly, the car wouldnt fire up. The guy thinking I installed them wrong, went to town on the firing order! Even when he got the firing order right, the car still wouldn't fire up. I put the stock wires back on and walla!
Old 03-16-2003, 11:24 AM   #11
JDMjdawg's Avatar
Yeah, your car is fine. I'm **** about things like that too when it comes to my car. I put a set of Nology wires on my car and it wouldnt start either. I just stick to stock NGK's, they work the best.
JDMjdawg is offline   Reply With Quote
Old 03-16-2003, 11:37 AM   #12
MrJasey's Avatar
Default Re: Starting car with wrong firing order cause damage? (JDMjdawg)
it will run on 3...just crappy
i would never have someone wok on my car that A. didnt know stuff AND B. that wouldnt look up info he wasnt sure about
MrJasey is offline   Reply With Quote
Old 03-16-2003, 11:57 AM   #13
official honda whore
EARLdaSQUIRREL's Avatar
Default Re: Starting car with wrong firing order cause damage? (MrJasey)
it would run on 3, actually my friends sol is running on 3 cylinders now , lol sounds like a damn helicopter
EARLdaSQUIRREL is offline   Reply With Quote
misfire on cylinders 2 & 3 Project_EK Tech / Misc 3 05-27-2009 06:17 PM
Newbies new project now won't start..what did I do? bandit67 Honda Civic / Del Sol (1992 - 2000) 1 03-21-2009 11:41 AM
Fuel and Spark but not start InJ3cted Honda CRX / EF Civic (1988 - 1991) 2 10-21-2005 09:19 PM
HELP! new clutch, tranny and ITBs.... car won't run -DC2- Tech / Misc 3 03-22-2004 09:49 AM
A/C affecting idle? M.A.R.C. Tech / Misc 2 05-14-2002 06:53 PM
Tags
95, cam, car, civic, damage, fireing, firing, honda, incorrect, order, overhead, run, single, vtec, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
