SRS light won't reset
Old 06-02-2014, 05:35 PM
todenbach's Avatar
Default SRS light won't reset
Just changed the steering column in my sons 95 Civic thinking that a wrecked car probably had a good clock spring. Not. SRS light still on and horn won't work. Bought one off Ebay and the horn works but SRS light is still on and won't reset using the paperclip trick. After fighting the light all afternoon I gave up. After walking away I got to wondering if the driver seat being out of the car would screw things up. I am too old and stiff to get under the dash with the seat in. Does anyone have experience with this kind of thing?
Old 06-02-2014, 06:17 PM
Former User's Avatar
Default Re: SRS light won't reset
You failed to mention how you reset the SRS computer.
Old 06-03-2014, 08:14 AM
todenbach's Avatar
I used the paper clip and the yellow connector next to the steering column. I did what several folks on youtube did with success. With the connector jumped I turned on the ignition and waited for the light to go off and it never did. I used the wire that has a socket but doesn't actually plug into anything. It seems like the clock spring is probably good since the horn works well. I would appreciate any suggestions you can offer. I think maybe I am getting too old to work on little cars except that we have four Honda's in the immediate family and they are great cars.
Old 06-03-2014, 08:33 AM
Post pictures/video showing how you did the reset procedure.
Old 06-03-2014, 09:07 AM
todenbach's Avatar
Being a computer idiot I don't know how to do post pictures or video. The basic process was jump the connector with a paper clip, turn on the ignition and wait for the light to go off then unplug the jumper and it goes back on, then jump it again and it goes off then unplug the jumper and the light flashes twice and you are finished. Turn the ignition off then back on and the light goes on for a few seconds(bulb test)then goes off. Unfortunately my light would never go off so I couldn't complete the whole process, Hope this helps this makes clear what I was trying to do. Thanks for trying to help.
Terry
Old 06-03-2014, 09:15 AM
Fish Twig
tony_2018's Avatar
If the bag deployed than the srs ecu has detect it. You'll probably need to replace the srs ecu
Old 06-03-2014, 09:58 AM
Pull the SRS code(s) by jumping the service connector.
Old 06-03-2014, 10:01 AM
ej6fade's Avatar
unless you need it for state inspection, just pull out the bulb from the cluster
Old 06-03-2014, 12:20 PM
todenbach's Avatar
Speedy 5966 posted what looks like a pretty complete list of SRS codes. Problem I have is the first code is 1-1 which doesn't seem to exist the second one is 5-1. I just don't see how any of this could have anything to do with a replaced clock spring. Would appreciate any suggestions.
Old 06-03-2014, 12:43 PM
The codes indicate a bad SRS computer (5-1) and a problem in the circuit for the airbag in the steering wheel (1-1). The latter may or may not be due to a bad clock spring or a bad airbag.
https://honda-tech.com/forums/showpo...00&postcount=4
Old 06-03-2014, 08:26 PM
todenbach's Avatar
I have looked for the last hour and can't find any info on how to troubleshoot the srs module or the airbag itself. Any suggestions very much appreciated. Has anyone ever had a clock spring that allowed the horn to work but stopped the srs light from being reset? I don't want to just start throwing parts at the problem.
Old 06-03-2014, 09:17 PM
Wdpfreak145's Avatar
Rip it all out and rewire the horn. Airbags included.
Old 06-04-2014, 04:24 AM
Code 5-1 indicates that the SRS computer is bad. It must be replaced.
For the airbag, start with the basics by checking whether it is plugged in and inspecting the wires.
The diagrams below are for 96-97 Civics. The troubleshooting should be similar but possibly not identical for the 95 Civic. Maybe somebody is willing to post similar troubleshooting diagrams for the 95 Civic, as well as the circuit diagram.
Old 06-04-2014, 07:35 AM
todenbach's Avatar
Thanks to RONJ@HT for the trouble shooting info. It looks to me like they are replacing the airbag with a two ohm resistor to simulate what the correct resistance should be through the inflator. If the light will then reset we can assume that the inflator is bad. This is assuming that the SRS module is good. Do you think that we can assume that the inflator resistance if measured with an ohmmeter would be two ohms? Thanks again for all your help. I don't really want to spend $150 for the box and special cable.
Old 06-04-2014, 08:02 AM
Old 06-04-2014, 11:58 AM
Sol to Sol
JarvisW's Avatar
First, 96-97 are different than 92-95. I got burned buying a set from Ebay that swore it would work.
Second, Looks like 5-1 still means "Internal failure of SRS unit" "Troubleshooting or SRS unit replacement"
1-1 is " Open in the Drivers airbag inflator or increased resistance"
So, there's your problem, likely.
It says to short the drivers airbag (with the red connector), but not the passenger. Then reconnect battery and get codes again.
If 1-2 then replace airbag.
If 1-1 ... well, lets just hope its 1-2 lol.. Lots of steps for 1-1, tho it hints about the the cable reel has an open, the SRS unit is bad, or the main harness..
I have the 94 Helms, but I don't have a scanner. The removal of the unit is the same tho. I haven't been able to verify the rest yet.
Old 06-04-2014, 12:04 PM
Can you take pictures of the relevant code troubleshooting pages as well as the circuit diagram with a camera or phone, and then post the pictures?
Old 06-04-2014, 12:27 PM
Sol to Sol
JarvisW's Avatar
I will try to tonight, tho I"d rather get good scans for everyone.
Hopefully I can borrow one soon.
With OPs having a resistor in place, I'll bet its not the right ohm, and is throwing the code because of that.
Old 06-04-2014, 12:28 PM
I never narc'd on nobody!
NotARaCist's Avatar
If it isn't posted by the time I get home tonight, remind me, and I'll post it from my FSM.
Old 06-04-2014, 12:34 PM
Why do you think that this^ has anything to do with code 5-1?
Old 06-04-2014, 03:20 PM
Fish Twig
tony_2018's Avatar
I'm sure that the srs ecu needs to be replace, or repaired, because the airbag deployed. Thats the only conclusion I can think of.
Old 06-04-2014, 07:19 PM
Sol to Sol
JarvisW's Avatar
Originally Posted by todenbach
Problem I have is the first code is 1-1 which doesn't seem to exist.
=It looks to me like they are replacing the airbag with a two ohm resistor to simulate what the correct resistance should be through the inflator.
I took that as his was replaced and according to the Helms its an open or wrong resistance as the cause of 1-1. He should still check it first as thats what the manual says.
Still working on other things, but I will try to have all the pages scanned soon.
Also, myairbags did my unit, and was very helpful, even tho I couldn't get it to work then, I didn't have the manual, they went ahead and refunded their fee. I'd try them before paying a ton for a new one. IMO would be better than trying a junkyard one.
Old 06-05-2014, 09:37 AM
Fish Twig
tony_2018's Avatar
If you're gonna source a junkyard you better make sure the airbags didn't deploy.
bestofthe80s
08-08-2013 01:12 PM
Jimmy604
01-13-2008 02:32 PM
S2k Hybrid
05-23-2007 09:37 AM
pennies_hatchie
10-20-2005 07:14 PM
Quick Reply: SRS light won't reset
