SRS Light Flashes When Checking For Codes
Old 10-23-2005, 11:11 AM
discrete's Avatar
Default SRS Light Flashes When Checking For Codes
When I jump the little connections to check my CEL code, instead of the CEL light blinking, the SRS light blinks non-stop. It just flashes on and off. I tried multiple times and each time, the SRS light blinks instead of the CEL.
This is a 95 Honda Civic EX
The connector I am jumping is blue with a green boot.
On the same wire loom is another connector with three contacts and is encased in some foam tape. I'm pretty certain I am jumping the right connector.
Anyone know how I can check my codes?
Old 10-23-2005, 12:07 PM
Echo7847's Avatar
Default Re: SRS Light Flashes When Checking For Codes (discrete)
Everything you described is normal, whats the problem? The cel will start blinking if a code is stored.
Old 10-23-2005, 12:39 PM
TheNasty0ne's Avatar
Default Re: SRS Light Flashes When Checking For Codes (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">Everything you described is normal, whats the problem? The cel will start blinking if a code is stored.</TD></TR></TABLE>
Did you even read? He said the SRS light is blinking not the CEL.
Well first off
https://honda-tech.com/zerothread?id=1171263
go there.
Old 10-23-2005, 06:22 PM
discrete's Avatar
bump
Old 10-24-2005, 08:49 AM
discrete's Avatar
nobody?
Old 10-24-2005, 08:53 AM
Will you make something up for me please?
shamoo's Avatar
Default Re: (discrete)
You are checking it correctly. Do you even have your CEL light on? You know you have to have a code first before it will tell you anything.
The SRS light blinking is the same thing, basically. You check your ABS error codes the same way you check your CEL codes. Count the flashes and look up your ABS codes.
Old 10-24-2005, 07:14 PM
discrete's Avatar
Yes... I do have a CEL. This is probably why I am trying to check it.
The SRS light blinks without stopping. I tried counting once and stopped counting at 73.
4DALOOKS92
04-16-2016 07:46 AM
streethondar
05-10-2015 07:12 PM
nerdboy1024
09-20-2007 02:17 PM
JDM-EJ1
04-05-2005 11:55 AM
Nikoli
05-03-2004 11:59 AM
Quick Reply: SRS Light Flashes When Checking For Codes
