Squeaking noise when pressing the clutch pedal
Old 06-10-2012, 10:29 AM
gnarlycs's Avatar
Default Squeaking noise when pressing the clutch pedal
I have a simple question. There isn't supposed to be any squeaking noise when you push down the clutch pedal is there? (doubt it) I wonder what could be causing it.
Last edited by Former User; 06-10-2012 at 10:41 AM. Reason: Post edit after redirect
Old 06-10-2012, 10:33 AM
Former User's Avatar
Default Re: Squeaking noise when pressing the clutch pedal
Does the noise come from near the clutch pedal or near the slave cylinder?
Old 06-10-2012, 10:35 AM
gnarlycs's Avatar
It's coming from outside of the car definitely. When I'm sitting in the driver's seat it sounds like it's coming from underneath the car.
Old 06-10-2012, 10:38 AM
MoreCowbell's Avatar
Clutch fluid. Mine tends to eat some after a while. If its low you might have gotten air in the lines
Old 06-10-2012, 10:39 AM
gnarlycs's Avatar
I have no clue how to bleed the clutch. I'll go check the fluid level. Also, it uses the same stuff as my brake master cylinder - DOT 3, right?
Old 06-10-2012, 10:41 AM
Try greasing the pocket in the clutch fork that the slave cylinder pushrod presses against.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-fix-squeaky-clutch-2673423/#post44452856
Old 06-10-2012, 10:53 AM
gnarlycs's Avatar
You know what, I just went outside to check the fluid level and I decided to check to hear where the noise was coming from and it didn't make any noise! I've had this consistent problem since I got the car and every day I drove it I heard it whenever I pushed the clutch down and I would think in my head "Okay, when I get home I'm gonna post about this on Honda-Tech and get this fixed." Odd that it isn't doing it now.
BTW the fluid level was fine.
Old 06-10-2012, 10:59 AM
92lxsleeper's Avatar
fluid level is fine, but its black as poo. i'd flush it anyways. grease the shift fork where it goes to the slave cylinder. worst case scenario is that its squeaking form where the shift fort pivets inside the bellhousing.
ps. mine squeaks and i dont care i can't hear it over the intake
Old 06-10-2012, 11:03 AM
DropSquadCivic's Avatar
Try doing this(it's under you dash where you clutch pedal is) and if that doesn't fix your squeak then I would bleed your clutch lines and try to get as much of that super dirty fluid out of the system. Use DOT-3 Brake Fluid.
Old 06-10-2012, 12:39 PM
gnarlycs's Avatar
What kind of greese/lubricant? Any special stuff or anything to stay away from? WD-40 good?
Old 06-10-2012, 04:32 PM
if you are going to grease that i would push the clutch in and apply a thin layer of wheel bearing grease. its thick and will stay in place for a while.
Old 06-10-2012, 05:19 PM
eingman's Avatar
could be a throw out bearing
cesar_civic_eg
05-01-2007 03:07 PM
TyPe_R_GuY
04-04-2004 12:23 AM
magic hat #9
12-23-2003 05:46 AM
PatrickGSR94
08-08-2002 04:16 AM
sa21199
08-22-2001 10:37 PM
Quick Reply: Squeaking noise when pressing the clutch pedal
