squeaking noise...need help
My cousin has a 99 honda civic ex with a gsr swap and for some weird reason it started making a squeaking noise yesterday. The squeaking noise only happens when hes off throttle and the car is rolling but the noise is not there when hes on throttle. The car sounds perfectly fine when hes idliing. Sounds like the noise is coming from the passenger side wheel. Anyone with any ideas please chime in.. THanks
Re: squeaking noise...need help (elektronsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elektronsi »</TD></TR><TR><TD CLASS="quote">check all the accessory belts, i bet its one of those</TD></TR></TABLE>
what accesory belts are u referring too?
Re: squeaking noise...need help (civicb16eg)
should be one of the bearings on the ac belt side or the bearing of the wheel or the belt a little un tensioned thats why when you switch off it "sounds" because the belt when you switches off relases from the thightening of engine rotation
Re: squeaking noise...need help (Pleiadi79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pleiadi79 »</TD></TR><TR><TD CLASS="quote">should be one of the bearings on the ac belt side or the bearing of the wheel or the belt a little un tensioned thats why when you switch off it "sounds" because the belt when you switches off relases from the thightening of engine rotation</TD></TR></TABLE>
When u say the belt, you're talking about the timing belt correct?
hondahead_dave
Honda Civic (2006 - 2015)
05-11-2011 06:40 PM
