Speedometer/Tachometer Problem HELP!!!!
Old 11-27-2009, 07:39 AM
B18CTYPER2000's Avatar
Icon3 Speedometer/Tachometer Problem HELP!!!!
I have a 2000 Honda Civic Si body with a 99 Civic EX motor (long story on that) however my tachometer and speedometer does not work. I have checked the speed sensor and Im getting fire from that all the way to the connectors on the back of the gauge cluster but still no working speed/tach. I have ever tried swapping gauge clusters and that still has not worked. There is the CEL on, but i doubt that has anything to do with this issue. Can anybody else me out with this?
Old 11-27-2009, 10:40 AM
TheCivicMafia's Avatar
Default Re: Speedometer/Tachometer Problem HELP!!!!
Sorry im not an ek person but i had this problem with my prelude, theres a 7.5 amp fuse under the dash for the ECU / ECM / Cruise Control check this fuse. ( it may be listed different in the ek )
Old 11-27-2009, 04:45 PM
I have tried replacing the fuse earlier but still no change. This is really pissing me off!!!! Thanks for your help.
Old 11-27-2009, 07:15 PM
American.Graffiti's Avatar
Check the circuitry on the back of the cluster. Sometimes the mapping gets fried. And if it is use the rear defog repair kit @ a local hardware store. (The copper paint thing that fixes broken circuitry for defog.)
Old 11-28-2009, 04:00 PM
I checked all the circuitry on the back of the cluster everything looks good. It just blows my mine that the fuel and temp gauge work. I have just given it up and bought a 5 inch tach but now having problems with that I hooked it up but the RPM's arent being reported correctly. Is the wire from the distributor the solid blue?
Old 11-28-2009, 06:05 PM
backyard_concepts's Avatar
try changing the cluster. I know it sounds dumb but sometimes its the dumbest answer that is the right one.
Old 11-29-2009, 06:55 AM
Hey backyard I already tried replacing the cluster and it still doesn't work. Do you know what wire i need to splice into to make my external tach to work? I tried the solid blue and the RPMS were showing real low. I was driving down the road testing it and my car hit redline and the tach was only showing like 3000 RPMS. I tried changing the wire to the green with yellow (or vice versa) i dont really remember, but it reported a little bit more RPMS but nowhere near what it is suppose to be displaying.... can you help?
Old 11-29-2009, 09:58 AM
96_cvc_b16's Avatar
the tach wire is the solid blue
Old 11-29-2009, 12:33 PM
I already tired the blue wire are we talking about the set of wires on the top side right next to the distributor? or on the bottom side? When i spliced into the blue wire on top the RPMS were reading LOW. I was idling at like 200 RPMS and never got past 3000 RPMS at redline.
Sam19
07-03-2018 02:48 PM
88aeFC3S
08-04-2008 12:41 PM
95hondacivy
08-28-2006 06:06 PM
ithinkitsjdm
13
02-23-2005 06:17 AM
Quick Reply: Speedometer/Tachometer Problem HELP!!!!
