Speedometer randomly stops working - Honda-Tech
Old 12-05-2011, 12:23 PM   #1
Default Speedometer randomly stops working
I'm pretty sure there's a thread about this somewhere, but I want specifics.
I have a 92 Civic hatch, and all of a sudden my Odometer randomly stops working, and randomly turns back on when it wants to. Sometimes when i take bumps it goes off too. Any ideas?
Freckles is offline   Reply With Quote
Old 12-05-2011, 12:24 PM   #2
Default Re: Odometer randomly stops working
Does the speedometer stop working when the odometer does?
Former User is offline   Reply With Quote
Old 12-05-2011, 12:24 PM   #3
kaiba's Avatar
Defected odo/speedometer or possible bad VSS(vehicle speed sensor)
kaiba is offline   Reply With Quote
Old 12-05-2011, 12:35 PM   #4
I'm not an idiot when it comes to this **** but I'm confused with the two ( odometer / speedometer )
And it was working just fine.. for a while, and it randomly stops working all of a sudden.
Old 12-05-2011, 12:36 PM   #5
Technical Hero
HondaPartsHero's Avatar
HondaPartsHero is offline   Reply With Quote
Old 12-05-2011, 12:38 PM   #6
Quote:
Originally Posted by Freckles View Post
...but I'm confused with the two ( odometer / speedometer )
What you are saying here?
Old 12-05-2011, 12:40 PM   #7
kaiba's Avatar
So you're saying your speedo works correctly but the odometer is faulty?
Old 12-05-2011, 12:41 PM   #8
Quote:
Sorry I mixed the two up. The speedometer randomly stops working, but the odometer works perfectly fine.
Old 12-05-2011, 12:44 PM   #9
kaiba's Avatar
Most likely your speedometer gauge is defected. This is a common problem. Find yourself another cluster and swap it.
Old 12-05-2011, 12:47 PM   #10
Alright. i'll try that. But also, my friend just bought himself a civic too, and the dude told him that the oxygen sensor is what's causing that to happen. idk if he's talking out of his ***, or it could be possible. And any suggestions on a nice cluster?
Old 12-05-2011, 12:51 PM   #11
kaiba's Avatar
Any cluster from a Civic 92-95 will be plug and play(including the automatic). If your Civic doesn't have the factory tachometer. This might be a good time to look for that cluster.
Sorry can't comment on the o2 sensor issue.
Old 12-05-2011, 12:54 PM   #12
Default Re: Speedometer randomly stops working
Title corrected.
Are you absolutely sure the odometer and tripmeter continue to work fine when the speedometer does not?
And no, a bad O2 sensor would have no effect on the speedometer.
Old 12-05-2011, 01:02 PM   #13
Marvin1985's Avatar
To put this in dummy terms. Your MPH gauge randomly cuts out. I have exact same issue. I'm assuming it might be the speed sensor.
Marvin1985 is offline   Reply With Quote
Old 12-05-2011, 01:08 PM   #14
It's not a speed sensor problem if the odometer or tripmeter actually works all the time.
Old 12-05-2011, 01:28 PM   #15
Odometer works perfectly fine, and so does tripmeter. only the speedometer doesn't work.. What could it be
Old 12-05-2011, 01:28 PM   #16
Replace the speedometer or cluster.
Old 12-05-2011, 02:52 PM   #17
angrysmileyface's Avatar
I had this problem, the circuit board went bad on the back my spedometer. I swapped one in from a used cluster, works fine didnt lose my milage or anything else. Kept the rest of my original gauges as well. I changed the VSS first being that it was 15$ and 20 minutes worth of time. Usually the culprit is a bad set of solder joints and being that I didnt want to spend time resoldering the entire circuit card, I just swapped it from another cluster that someone had botched a face covering install
angrysmileyface is offline   Reply With Quote
Old 12-05-2011, 02:57 PM   #18
Marvin1985's Avatar
I'm getting a new cluster myself since I need the rpm gauge anyway.
Old 12-05-2011, 05:55 PM   #19
street_racer_271's Avatar
ive got clusters if anyone needs...
street_racer_271 is offline   Reply With Quote
97 accord pas window randomly stops working help.. steven.shutz Honda Accord (1990 - 2002) 6 01-19-2012 05:18 PM
ebrake light comes on randomly ej6kid Honda Civic / Del Sol (1992 - 2000) 8 11-01-2010 07:55 PM
FS: 1998 Turbo LS (449 whp) GAtegs Southeast (Sales) 40 11-21-2009 03:10 PM
Start then immediate stop. reddigitaldragon Honda Accord (1990 - 2002) 4 10-20-2003 09:14 AM
BRAKE and ABS Lights On/Off Randomly... hankd Honda Accord (1990 - 2002) 3 08-14-2002 05:27 PM
Tags
1990, accord, doesnt, g2, honda, integra, mph, odometer, random, randomly, speedometer, stop, stops, tech, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
