Speedometer Problem
Speedometer Problem
Quick rundown of what happened. I was changing the transmission fluid in my 97 civic and did not have a hose or pump to put the new fluid in the fill spot so I removed my speed sensor and filled the transmission through there with 1.8 quarts of Honda MTF.
Speedometer worked perfectly before and then when I go to put the sensor back in and reconnect the connector, speedometer doesn't work. I've replaced the speed sensor with 2 others, the connection is good, and the cluster is good. What else could I or should I check to fix this problem?
Re: Speedometer Problem
yeah I checked that too and no it wasn't blown. I even went ahead and changed it out for a just in case and still nothing. thanks for at least giving an idea though. it's appreciated.
Freckles
08-20-2012 10:30 PM
speed.freak
06-08-2005 01:40 PM
