Speedometer/Odometer Problem.
Old 05-26-2008, 07:01 PM
HachiGo's Avatar
Default Speedometer/Odometer Problem.
Hi, noob here.
I have a auto '96 Civic DX hatch.
Recently the speedo and odometer will stop working randomly, like the needle will fall to zero and the odometer wont record miles driven.
Usually it will correct itself or if I push the odometer reset thing down it will work again.
Any idea whats causing this? Or how to fix?
Any help is appreciated.
Old 05-26-2008, 07:05 PM
Berge9798's Avatar
Default Re: Speedometer/Odometer Problem. (HachiGo)
Does your car have the Required service indicator on it?? if it does make sure nothing is stuck in the reset for that. My gauges died on me because that reset button broke when i pushed it in. I ended up having to get a new cluster
Old 05-26-2008, 07:19 PM
HachiGo's Avatar
Default Re: Speedometer/Odometer Problem. (Berge9798)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Berge9798 &raquo;</TD></TR><TR><TD CLASS="quote">Does your car have the Required service indicator on it?? if it does make sure nothing is stuck in the reset for that. My gauges died on me because that reset button broke when i pushed it in. I ended up having to get a new cluster </TD></TR></TABLE>
I do have the required service indicator, how do i make sure nothing is stuck in reset for it?
Noob here...
Old 05-26-2008, 07:23 PM
Berge9798's Avatar
trying pushing it in and see if it come back out. it should be a little stiff to push in
Old 05-26-2008, 07:26 PM
averyvm's Avatar
He was talkin about the reset button that resets the recorded miles. He asking you if your button is stuck. To see if its stuck push in the button and see if it resets the miles
Old 05-26-2008, 07:29 PM
Berge9798's Avatar
Default Re: Speedometer/Odometer Problem. (averyvm)
no i was not talking about the trip meter. I was talking about the service indicator
Old 05-27-2008, 10:12 AM
HachiGo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by averyvm &raquo;</TD></TR><TR><TD CLASS="quote">He was talkin about the reset button that resets the recorded miles. He asking you if your button is stuck. To see if its stuck push in the button and see if it resets the miles</TD></TR></TABLE>
No, my button is not stuck, it does reset the recorded miles. Sorry if i didnt make that clear.
Old 06-05-2008, 01:33 PM
meanshyguy's Avatar
I got the same problem, got another cluster at ebay, same thing, this one doesn't even jump a bit, it's totally dead. don't know what to do. VSS is ok, honda checked it.
Old 06-05-2008, 11:21 PM
NJEK's Avatar
Default Re: Speedometer/Odometer Problem. (meanshyguy)
I have the exact same issue. The only thing I have been able to figure out (after a 2500-mile drive from Utah to New Jersey) is that the speedo and odometer come on faster if I turn my heater on...also the selector switches on my climate control don't work correctly; the air ONLY comes out the dash vents, no matter what selection I make.
Perhaps the problems are related, perhaps not. My speedo was also reading 20 mph higher than actual speed. I took my dash and speedo apart, but couldn't find anything mechanically wrong, although I managed to fix the 20mph disparity by taking the needle off and putting it back on in a slightly different position. I will therefore assume that it is electrical, and that perhaps the heater loosens things up a bit under the dash (the speedo WILL NOT work in the cold weather). Please try this and let me know if that is the case for you, too.
Old 06-07-2008, 05:56 AM
NJEK's Avatar
I found a solution!!! (maybe)
This problem is all over the net. People are clearly confused and MOST of the forum posts are recommending changing the VSS and the cluster, followed by 1 guy saying "Thanx, that worked," and 15 people saying "HEY I JUST SPENT $400 AND STILL HAVE THE SAME PROBLEM!" A lot of times people with this speedo problem are blowing fuse 15 every time they start the car, and the problem seems to get progressively worse over time. Also, like with mine, several people noticed that having the heater on made a difference. So...apparently there is either a short or a loose connection somewhere, right?
Well, I searched dozens of forums, and a couple of them eventually led me in the right direction. They say that behind the intake manifold the wires rub and get exposed. I guess all you need to do is get under the car, reach up there and put some electrical tape on the bare spots, then make sure fuse 15 is still good. Everyone reported *problem solved* after doing this.
I will do this today and let you know.
Modified by NJEK at 7:38 AM 6/7/2008
Old 06-07-2008, 07:20 PM
Irritated_Onion's Avatar
Default Re: Speedometer/Odometer Problem. (NJEK)
Take a photo of where the wires are rubbing on your vehicle!! I'm working on this problem myself. I pulled the VSS and the plastic gear teeth look fine
Old 06-09-2008, 12:42 PM
meanshyguy's Avatar
Default Re: Speedometer/Odometer Problem. (Irritated_Onion)
Yeah, there's a lot of wires by the IM, take a pic if you can, I have two gauge clusters with the same problem, I don't think it's the clusters, and I've been trying to fix this since a while back.
Old 06-10-2008, 10:43 PM
NJEK's Avatar
sorry all, i've been out of town for work, haven't had a chance to do it. I did notice, though, that one post I found said it was the firewall rubbing through the wires, and another post said that the wires rubbed raw against the intake so...ya, I guess there are a lot of potential problem spots. I need to do some cleanup in my engine compartment anyway so I'm just gonna look at everything. Get pics when I have a chance.
Old 06-16-2008, 01:58 PM
meanshyguy's Avatar
took the whole thing apart, nothing seems to be burnt or stuck on the gauge cluster, wires by the firewall do not rub, I'll double check this weekend to make sure
D16Y7EJ1
02-16-2013 05:05 AM
jomama
09-25-2007 07:02 AM
95hondacivy
08-28-2006 06:06 PM
Maxime
03-23-2006 08:25 PM
92SleeperH23
04-18-2005 06:45 PM
Quick Reply: Speedometer/Odometer Problem.
