speedometer & odometer not working!!
alright my speedometer & odometer is not working. if it was the vss sensor would that mean the odometer wouldnt work too? any ideas? ive been driving without a speedo for a month now and got to get this fixed!
Re: (xavenged7x)
I know exactly how you are feeling about not having your Cluster work man. Mine has been messing up since last summer when i thought i would install Glow Gauges on my cluster. After that I have had problems since, I bought a new cluster off ebay(without glow gauges) and it still acts up. Its better but still bounces. Try hitting your dash a few times...seems to work for me. My problem i would think would be the wiring behind the dash. But I have done damn near everything. One of these days i will probly try to install a new VSS. but if it was bad im pretty sure it throws a code, but never know till i try.
Re: (pro1342)
Your VSS is out, Definatley. Thats the main problem, something with that.
And yes it makes the odometer not work.
Have it looked at, and if it is the speed sensor, just find a cheap one off ebay or something.
-Rob
-Rob
Re: speedometer & odometer not working!! (civicguy167)
the speedometer works in conjunction with the speedometer and they often go bad in the usdm clusters..i have had 2 go bad
all this happened when i did my last swap. im gonna go pull a vss out of a civic at the junkyard and throw it in there and see if it fixes the problem
Re: (civicguy167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicguy167 »</TD></TR><TR><TD CLASS="quote">all this happened when i did my last swap. im gonna go pull a vss out of a civic at the junkyard and throw it in there and see if it fixes the problem</TD></TR></TABLE>
have you even checked the CEL code yet???
ma_rio44
11
07-15-2007 09:24 AM
