Some troubles after brake bleeding
Old 07-04-2004, 04:43 PM
jetpilot's Avatar
Default Some troubles after brake bleeding
I bought my car about 6months ago and the brake pedal felt soft from the beginning. Now I bought stainless brake lines and decided to change to ATE Super blue racing fluid. I took off all rubber lines and all the fluid from the MC poured out, I even added some cheap brake fluid to kindoff flush the lines from dirt.
Next I installed my SS lines and bled all the calipers in the correct sequence, twice. The pedal still feels soft and Im thinking either the MC is damaged of there is air in the system (mainly in the MC but I dont know how to bleed that).
What should I try? How do I bleed the MC if there is even such a thing. How do I test the booster and MC?? thanks
Old 07-04-2004, 09:31 PM
BanEL's Avatar
Default Re: Some troubles after brake bleeding (jetpilot)
does the pedal feel soft when u have the car running?
or
does the pedal feel soft when the car is not running
Old 07-04-2004, 11:42 PM
dogfood's Avatar
You need to bench bleed the master. I wouldn't know how to describe how to do it and I don't have a digi cam. If you bench bleed the master and it still has a mushy pedal then I would say that you have blown seals in the master. If you understand how a master cylander works then you should be able to figure out how to bleed it.
Old 07-05-2004, 12:37 AM
LSpimpTEC's Avatar
Default Re: Some troubles after brake bleeding (dogfood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogfood &raquo;</TD></TR><TR><TD CLASS="quote">You need to bench bleed the master. I wouldn't know how to describe how to do it and I don't have a digi cam. If you bench bleed the master and it still has a mushy pedal then I would say that you have blown seals in the master. If you understand how a master cylander works then you should be able to figure out how to bleed it.</TD></TR></TABLE>
http://www.autozone.com/servle...9.jsp
might help some
Old 07-05-2004, 08:45 AM
dogfood's Avatar
Default Re: Some troubles after brake bleeding (LSpimpTEC)
nice, thanks for the backup.
Old 07-05-2004, 08:47 AM
drunknbass's Avatar
you need to bleed the system more than twice.. if you have that much air youll prob go through alot of fluid till it gets stiff.. and you dont need to benchbleed the mc.. you didnt even change it why would you bench bleed it?. thats if its dry and doesnt have fluid in it
Old 07-05-2004, 09:09 AM
jetpilot's Avatar
it feels mushy with the car on and hard when its off. Im going to rebleed the calipers to see if it fixes it and try to bleed the mc but Im not sure how to do with it still in the car
Old 07-05-2004, 06:48 PM
dogfood's Avatar
Default Re: Some troubles after brake bleeding (drunknbass)
the only reason I say bench bleed the mc is because that would rule that out. I guess I just like to cover every angle. no biggie
jwlee7ucla
04-14-2024 07:41 AM
boostedteg1203
01-21-2010 05:58 AM
dgdarien
09-25-2009 06:25 PM
stripes777
10-28-2006 11:16 PM
The_In_Kid
07-07-2002 11:45 PM
Quick Reply: Some troubles after brake bleeding
