some advice
Re: some advice (jwizzie2001)
when your temp gauge reads halfway it should kick on untill it goes a little below halfway. and yes without the fan it will quicly over heat.
Re: some advice (TravisCadello)
It varies on ambient temps and the like. I know on my 6th gen, stock, at operating temp and having it parked it can take up to 5 minutes or so. Without it, you'll more than likely start to see the temps rising until you get some air moving around there.
at approx. 217 deg on off at approx. 180-190 deg. i do belive(not sure) and yes the car will overheat if you slow down enough to stop the airflow across the radiator ie. at stoplights and stop and go traffic. that im sure of..
T_ypEr
23
05-14-2011 03:47 PM
turbotime
11-14-2005 12:45 PM
