SOHC timing belt teeth???? - Honda-Tech
Old 04-03-2006, 12:39 PM   #1
RICE POLICE SIP's Avatar
Default SOHC timing belt teeth????
Does anyone have a run down of all the SOHC timing belts and how many teeth they have? Or where I can find the info? Anywhere from EF's to the 7th gen civics... TIA
RICE POLICE SIP is offline   Reply With Quote
Old 04-03-2006, 02:20 PM   #2
Default Re: SOHC timing belt teeth???? (Split Image Prez)
I put a 92-95 civic head (d15b7) on a 96-97 del sol block (D16y7) and now the y7 timing belt is to short... anyone know of any longer belts?
Old 04-04-2006, 09:59 AM   #3
well after a little research and counting of teeth on timing belts I find that on the 91 CRX si 1.6L belt you have a 106 tooth belt and a 107 tooth belt... The D16Y7 belt has 104 teeth... I'm still doing a little more research but I ended up buying the 107 tooth belt...
Old 04-04-2006, 03:56 PM   #4
anyone know any of the other belt tooth counts?
Old 04-04-2006, 03:58 PM   #5
SVOboy's Avatar
Bump for fun, this'd be good info to put in a FAQ.
SVOboy is offline   Reply With Quote
Old 04-04-2006, 04:24 PM   #6
92hatchling's Avatar
Default Re: (SVOboy)
it the b7 belt your looking for you almost always use the belt for the head you use
92hatchling is offline   Reply With Quote
Old 04-04-2006, 04:51 PM   #7
Default Re: (92hatchling)
Quote:
That's what I was thinking too, but then I was thinking if it's a 1.5L block why would the belt be longer.. I stopped by Auto Zone and the CRX si belt have the same part number as the D15b7 belt.. But one is a 1.5L and the other is a 1.6L also..... When they pull up the 91 CRX 1.6L in the computer it asks you 106 or 107 tooth... Why would they be different?
Old 04-04-2006, 05:03 PM   #8
mc
mc's Avatar
Default Re: (Split Image Prez)
the d15z1 belt is 103 teeth
edit:
actually I found some more after searching a little
The VX timing belt has 103 teeth, where as the Z6 timing belt has 104 teeth, and the B7 belt 106 teeth.
Modified by mc at 9:12 PM 4/4/2006
mc is offline   Reply With Quote
Old 04-05-2006, 09:27 AM   #9
Default Re: (mc)
Quote:
edit:
WOW 103 lol Thanks for the info! I put the 106 tooth belt on and it seems to be just fine... knock on wood... LOL
Old 06-10-2007, 10:01 PM   #10
Metal Head's Avatar
Default Re: (RICE POLICE SIP)
does vtec and non vtec affect the belts length? I have a d15B vtec, im looking for a belt for it, I assume the d16z6 belt would work cuz its VTEC, so I have to use a 1.5L belt, does it HAVE to be vtec? or can I buy a 1.5L non-vtec belt??
Metal Head is offline   Reply With Quote
B18c timing not aligning??? EF'GSRrr91 All Motor / Naturally Aspirated 4 01-20-2015 01:48 PM
JDM D15B Vtec timing belt - cannot get the teeth exactly lined up Kush2Slow Honda Civic / Del Sol (1992 - 2000) 3 03-16-2014 11:59 PM
PSA - Check your aftermarket cam gears for wear! erikiksaz1 Acura Integra Type-R 11 04-24-2009 11:38 AM
Whining Noise from Belt Area After Timing Belt Replace? Jk_DC2 Acura Integra 5 03-08-2009 11:11 AM
d16z6 timing belt, anyone know how many teeth? Timmay Honda Civic / Del Sol (1992 - 2000) 10 11-05-2004 08:26 PM
Tags
106, b7, belt, civic, d15b7, d16y7, difference, honda, numbers, part, teeth, timing, tooth, y7, z6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
