sohc sputtering at partial throttle....no spark ?
Ok, this is the deal, 95 D16Z6, I have a code 23 (I think that was the #) For H02S (O2 Sensor) So the aftermarket (not stock) O2 sensor I have may be gone... but the distributor cap/rotor look ok.
When at partial throttle in any gear, only at lower rpm, like 2-3K, if I give it some gas, it goes and gives a little sputter a couple times until/unless I put the gas down (basically raise the rpm) the sputtering stops and the car accelerates briskly.
EgI: Pulling off in 1st, calmly... the engine purrs, engaging clutch, intially car will start to sputter/hesitate, but if I give it more gas... the sputter stops.
EgII: If I were crusing along at say 40 and I put it in 5th and give it a little gas, the engine will sputter some until I get higher in the rpm band.
Any one have this problem ? Any diagnosis' ?
The plug wires are Accell POS... I need some stockers.... the plugs are pretty new.
X2
X2
h_civ2000
11-20-2010 12:30 PM
ShinotakuX
02-07-2008 06:54 AM
