So I checked my CEL and.....
Old 10-19-2009, 09:59 AM
odidipissuoff's Avatar
Default So I checked my CEL and.....
This is what i got
Cel#
12-(ERG) Exhaust gas recirculation lift valve
41- Primary Oxygen sensor heater
48- Lean Air fuel Sensor
71- Random misfire Cylinder 1
72- Random misfire cylinder 2
73- Random misfire cylinder 3
74- Random misfire Cylinder 4
FML!!!
Anyone have any clues on how to Fix 71-74?
Old 10-19-2009, 12:35 PM
Default Re: So I checked my CEL and.....
I cleaned my IACV and now my car dies when i push the clutch in to coast (i.e. to turn or something like that.)
I parked it in the driveway and let it idle, it's idling right above zero. What could cause this?
Old 10-19-2009, 12:56 PM
ferio252's Avatar
CEL's 41 and 48 sounds like you have a bad oxygen sensor. A random misfire can come from fouled spark plugs. Check each and every spark plug for carbon damage, resistance and voltage.
Another source may be the fuel injection system. Make sure that your injectors are not dirty as this could cause a lean air to fuel ratio in all four cylinders. Also check fuel pressure. Do not rule out "bad" gasoline as this can also through off your fuel injections system.
Lastly, check your overall compression as there can be leaks in a headgasket etc, that can be causing the random misfiring.
Bump for someone with mroe excperience.
Old 10-19-2009, 01:32 PM
Thanks, we have had bad gas around here lately, but my check engine light has been since before the bad gas. I will check everything else you mentioned above and update.
Anyone else have any other suggestions? Especially on my second post?
Old 10-19-2009, 01:48 PM
Former User's Avatar
Clean out the EGR valve port and passages, and I think most of the codes will go away.
Old 10-19-2009, 01:49 PM
ferio252's Avatar
Werd^ Thanks RJ. That too
Old 10-19-2009, 03:54 PM
I will get to that on Wednesday, Any other suggestions? The ones provided are great.
Bigrome34
12
07-27-2010 01:01 PM
odidipissuoff
12-13-2009 07:27 PM
purple98ek
03-19-2006 07:04 PM
Tokidoki
11-09-2004 05:44 AM
Quick Reply: So I checked my CEL and.....
