94 civic Ex Front Breaks the same as 92-95 civic SI ?????
hey guys been doing a search and havent come up with any legit answer. I wanted to know if anyone can verify if the 92-95 civic EX have the same calipers and front breaks as a 92-95 civic Si........ ...........And if Yes, will it be the same as front GSR breaks...................Main thing is that I want to do a Front GSR break job and dont know what to get????? HELP PLEASE
I'm not Rick!
Re: 94 civic Ex Front Breaks the same as 92-95 civic SI ?????
they are the same. the gsr is a bit bigger. for the gsr, get the whole knuckle, rotor, caliper, hub etc. undo the upper and lower ball joint and take out the axle and take off the tie rod and thats what you take
The EX with ABS uses larger brakes, the same size as the teg rotors.
just get the gsr, its better anyways, but dont forget to get the master cylinder for it also. As mention, ex has abs and si dont. I dont know if they're differ or not I dont mess with it, only change brakes. Only thing I would know is gsr are bigger than si cause I had a gsr and si and the gsr was bigger.
VTECR021
04-20-2004 12:24 PM
