Smog for swapped motor
Old 01-31-2010, 11:10 PM
civicSF98's Avatar
Default Smog for swapped motor
If you have a swapped motor do you have to take
your car to a special Smog place to get it smogged?
I went to this car shop and they told me they couldn't
smog my car because it had a swapped motor.
Old 02-01-2010, 11:06 AM
fungus mungus's Avatar
Default Re: Smog for swapped motor
Are you CA? if so, you have to get the motor examined by the state ref for the BAR. Call up the state BAR ( 800.952.5210) and make an appointment. They'll make an appt for you at the closest facility to you (usually a community college) and you'll take it there and let the guy go over your swap with a fine toothed comb. Assuming it passes muster, he'll give you a BAR sticker and then you can take it to get it smogged. Be warned, the state ref will be really picky when he goes over your swap, so if you cut any corners, didn't plug everything up like factory, or jerry-rigged anything, you'll be going home with a disappointed look on your face and instructions on what to do to fix the problems they've found. Good luck!
fm
Old 02-01-2010, 11:00 PM
civicSF98's Avatar
fm
Thanks for the info. I smogged my car before and past last time. I just didn't get the guy when he told me I needed to take it to a bar smog station.
BRIANxJDM
35
05-11-2013 09:49 PM
dubeedoo209
10
05-19-2008 01:58 AM
hatchish
11
09-09-2005 12:45 PM
jeffk182
12
07-09-2004 10:12 AM
EF-9SiR
18
01-10-2003 12:10 PM
Quick Reply: Smog for swapped motor
