smog question regarding CA
hey guys, my i took my car to get it BAR'd last week, and the visual passed but the smog part didnt, it failed the CO and the NO part.... the CO failed at 25mph(MAX= .51, MEAS=1.27) and the NO failed at 15mph(MAX= 708, MEAS= 1681)....so i failed by a pretty big margin. what can i do to make it pass next time around? the tech said that it can be due to carbon build up, how can i clean it out? i heard that i can use two cats... is that true? suggestions would be greatly appreciated....
sidenote
set-up: 94 hatch vx with a 94 b18b1 motor
sidenote
create a custom exhaust with 2 cats if you wanna pass that badly....seafoam the car?
no idea what else......
sidenote question
was the b18b a usdm or jdm? if it was a jdm what did you have to change to make it usdm?
sidenote question
Re: smog question regarding CA (byronl)
nah i havent replaced it, i was planning on doing so after i seafoam my motor and try to clean it as much as possible... also thinking of replacing the cat... any ohter ideas?
Re: smog question regarding CA (mighty_sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mighty_sol »</TD></TR><TR><TD CLASS="quote">seafoam and change the oil and air filter...that should do it</TD></TR></TABLE>
Yes, and make sure that your 02 sensor and catalytic are working properly, and you should be okay.
Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez »</TD></TR><TR><TD CLASS="quote">I have a question. The c/r on a stock b18b is around 9.3-.5:1 right? I replaced the pistons with CP rated at 9:1 and had the block and head milled to the thousand of an inch. Think it'll pass smog?</TD></TR></TABLE>
No.
No.
