small light fuse? need some help
Old 06-08-2006, 02:50 AM
Patrick_S's Avatar
Default small light fuse? need some help
okay i have a 93 civic hatch cx and my parking lights, cluster light, and tail lights don't work. and i've searched and everyone says that its the "small light" fuse that should be broken.. and i can't seem to find the fuse under the hood. can someone show me a picture or diagram that will show me where this small light fuse is?
Old 06-08-2006, 03:02 AM
john666's Avatar
Default Re: small light fuse? need some help (Patrick_S)
the fuse box under the hood near the car battery.. there are like 5 6 fuses there. im sure if u look u will see if there is one that needs to be replaced.
Old 06-08-2006, 03:22 AM
Patrick_S's Avatar
Default Re: small light fuse? need some help (john666)
sorry i should have clarified my problem more.. i know where the fuse box is.. but i need to know where exactly the "small light" fuse is..
here is a picture of my fuse box under my hood..
i don't see any broken fuses so im guessing the small light fuse is somewhere else... does anyone know where it is located in a 93 civic eg?
Old 06-08-2006, 03:39 AM
VRD^don's Avatar
hmmm this actually happened to me before..but it was the back up fuse(7.5amp) keep blowning cause the radio/ head unit wiring kept on shorting..fixed it and nomore blown fuses..yes it took out all my tail lights and parking..
Old 06-08-2006, 06:34 AM
EJ1_Sleeper's Avatar
I had this same exact problem. first check to make sure you dont have any wires touching (perviouis owner rigged the spolier light wrong and the wires melted) and then i believe its the 20 amp stop/horn. i kept blowing them left and right. even got pulled over for it.....
Old 06-08-2006, 07:07 AM
stock_honda_coupe's Avatar
Default Re: small light fuse? need some help (EJ1_Sleeper_Coupe)
theres also fuses under you dash. The ones under the hood are the bigger ones. The ones under the dash are smaller and more specific.
dansaleen_04
07-22-2013 11:19 AM
1992gsrblack
05-03-2011 12:32 PM
Shannon626
05-29-2008 11:03 PM
guywitaDA
04-21-2004 09:58 PM
Quick Reply: small light fuse? need some help
