Which Skunk2 Cams Should I Use?
Old 02-07-2009, 02:43 PM
EGCoupeVtec's Avatar
Default Which Skunk2 Cams Should I Use?
Im building a motor which is going to be ls/v boost. As far as the parts i have for the head this is my set up
Skunk2 Pro Cam Gears
Skunk2 Pro Dual Springs
Skunk2 Titanium Retainers
Skunk2 Pro Series Valves
Skunk2 Fuel Rail
Edelbrock Victor X Intake Manifold
Blox 72mm Throttle Body
I was wondering which Skunk2 Cams should i be using Stage 1,2 or 3? Im looking from 600-650 hp.
Old 02-07-2009, 02:48 PM
tercel95's Avatar
Default Re: Which Skunk2 Cams Should I Use?
Get the TURBO stage 2 cams. The regular cams will ruin your setup because of increased overlap... They make cams specifically for turbo cars, that is what you need to get...
Old 02-07-2009, 03:09 PM
1LowSol's Avatar
Originally Posted by tercel95
get the turbo stage 2 cams. The regular cams will ruin your setup because of increased overlap... They make cams specifically for turbo cars, that is what you need to get...
+1
Old 02-10-2009, 03:17 PM
i decided to go with the skunk2 pro series stage 1 cams they hold pretty good.
Old 02-10-2009, 03:18 PM
93egSLEEPER's Avatar
ITR's are nice with boost
Old 02-10-2009, 11:26 PM
yeah i heard about those too but i also heard they only hold up til around 500hp
Old 02-11-2009, 02:49 AM
civicboy1128's Avatar
good choice the pro1s are the best cams to go with on a turbo build. they put out more power than the stage2 turbo cams and the pro2s have too much overlap
Old 02-11-2009, 06:00 AM
Thanks bro. The shop im always going to had told me to go with the pro1s and that they will hold up the hp i will be putting down. So i decided to go with those we'll see what happens and what numbers i will be putting down.
phaphon
05-21-2010 02:17 AM
civicegsick
11-29-2009 01:08 AM
patrick4588
07-16-2008 11:27 AM
egVTI
07-01-2006 07:09 PM
amazinspiderman
09-18-2004 09:00 PM
Quick Reply: Which Skunk2 Cams Should I Use?
