single wire 02 sensor to 4 wire...
i have a 94 cx hatch, has single wire 02 sensor. i have a d16z6 w/p28 which is setup for 4 wire 02 sensor. i have to use the engine harness from the cx... so how do i do that? i know i have to add wires for vtec, but do i need to chop the plug from my old harness off the crx and then run my own 02 sensor wires? thanks
Re: single wire 02 sensor to 4 wire... (SOHC Beast)
yes you do need too run the 4 wire if you are using the cx harness
if it is a 92 it is plug and play whin i did my swap i did not wire anything
Moderator
it is easier and best to just get the d16z6 wire harness and do it that way.....have have done 3 1 to 4 wire conversions and eventually they all throw a tps code....becuase you splice into the green wire on the tps or map sensor
Re: single wire 02 sensor to 4 wire... (chad)
so do i need to have a hatch Si harness, or will a civic ex harness work as well? and how much do you think it will run me for a harness in good shape..?
also, with the z6 harness... will it all plug in just fine at the strut tower clips? and how do i add the wires from the strut tower to he ecu? thanka a lot
chrismanis
11-06-2014 12:07 PM
