signal blinkers and emergency blinkers dont work!!
Old 02-05-2013, 09:10 AM
toby350's Avatar
Default signal blinkers and emergency blinkers dont work!!
Blinkers stop working after I took my dash off. Change the flash relay and emergency button and still nothing. Thanks for any help.
Old 02-05-2013, 09:58 AM
Former User's Avatar
Default Re: signal blinkers and emergency blinkers dont work!!
Check the hood hazard lights fuse and the dash turn signal fuse.
Old 02-05-2013, 11:09 AM
toby350's Avatar
I checked the hood hazard fuse but not the dash turn signal fuse. Is that located on the fuse box under tye steering wheel?
Old 02-05-2013, 11:19 AM
What car?
Old 02-05-2013, 11:24 AM
toby350's Avatar
Its a 93 civic
Old 02-05-2013, 11:28 AM
Voltage test 10A hood fuse 43 and 10A dash fuse 15. Both top tabs of each fuse should have battery voltage. Click the Test Fuses link in my signature.
If the above tests are fine, then make sure the hazard switch connector is fully seated. If so, unplug it and test whether battery voltage reaches the Wht/Grn and Yel wires in the connector.
Old 02-05-2013, 11:50 AM
toby350's Avatar
Ok ill check when I get home around 4. Thanks for your help.
Old 02-05-2013, 05:09 PM
toby350's Avatar
Ok checked it out and the hazards switch connector has power only on one wire and its white with a blue line. It also had power on a all yellow wire but only for a bit. If your holding it with the release clip on top, the two bottom right wires where the one with power. Also checked the hood fuse and that also has power but not the dash fuse. The fuse is good but theres no power coming out even took off the fuse and touch directly to the metal inside the fuse box and still nothing. Anything else I can check?
Old 02-05-2013, 06:09 PM
The Yel wire and dash fuse 15 must be voltage tested with the key in ON(II).
Plug the switch connector back in and then do these input tests:
Old 02-05-2013, 06:29 PM
toby350's Avatar
I did try it wen it was on. I took off my srs box when I did my brake tuck.
Old 02-05-2013, 06:33 PM
Does 20A dash fuse 14 have battery voltage on both test tabs?
Old 02-05-2013, 06:46 PM
toby350's Avatar
Does it have to be on? My sunroof works tough.
Old 02-05-2013, 06:47 PM
Yes. Key in ON(II).
Old 02-05-2013, 06:58 PM
toby350's Avatar
Ok yea I just check it and BOTH fuses have power I didnt have the key all the way the first time I checked.
Old 02-05-2013, 07:04 PM
Does battery voltage reach the yel wire in the hazard switch connector?
Old 02-05-2013, 07:14 PM
toby350's Avatar
Yea it has power.
See post #9.
Old 02-05-2013, 07:18 PM
toby350's Avatar
What you mean post #9?
Old 02-05-2013, 07:19 PM
Each post in a thread is sequentially numbered (#) in the upper right corner.
Old 02-05-2013, 07:25 PM
jbpnoman's Avatar
Post #9. In this thread.
Old 02-05-2013, 07:35 PM
toby350's Avatar
Ok I looked at it now what?? Does my cluster have anything to do with it?
Old 02-05-2013, 07:39 PM
Read the diagram and do the three input tests. Post each result.
Old 02-05-2013, 07:45 PM
toby350's Avatar
Ok ill do it tomorrow. Its dark and cold.
Old 02-05-2013, 07:51 PM
toby350's Avatar
So if im reading it right, all 3 must have power?
Old 02-05-2013, 07:55 PM
You need to read the diagram carefully.
Test #1 looks for ground not voltage (power).
Test #2 looks for voltage (power).
Test #3 looks for proper function.
Quick Reply: signal blinkers and emergency blinkers dont work!!
