si engine harness/ecu harness
Old 06-10-2007, 02:11 PM
Jdmdctek's Avatar
Default si engine harness/ecu harness
I got a 96cx hatch and i put a swap in it and i changed the engine harness to si and i got the boomslang obd2b to obd1 jumperharness and it plugs in but there seems to be that the engine harness is missing a plug and im not sure so i figured i would post on here and see.
Old 06-10-2007, 02:49 PM
Jdmdctek's Avatar
Default Re: si engine harness/ecu harness (JdmDctEk)
ttt
i want to drive my car already
Old 06-10-2007, 09:20 PM
hatchi's Avatar
what ecu are you running?? the 96-98 harness is different from 99-00
Old 06-11-2007, 04:11 AM
Jdmdctek's Avatar
well today im going to use my friends si ecu to see if it starts but i need another jumper harness for si harness. i got a obd2b jumper harness already but it seems like its missing a clip that plugs into the jumper. the computer im trying to run is a chipped p28
Old 06-11-2007, 04:17 AM
blaze the chemi's Avatar
Default Re: (JdmDctEk)
It looks like you have the B and C connector for the ECU. Where the hell is the A connector. It's another gray one that plugs into your conversion harness. Leave the green male pluged to the green female.
Did you drop in a B16? You do have a OBD2b -> OBD1 coversion harness right?
Old 06-11-2007, 07:55 AM
jdmej604's Avatar
si have a two part harness the other plugs on the interior wiring harness even if u have a ob2b to obd1 u still need the other plug so unless u plan on swaping the whole interior harness u need 2 run a 96-98 ex wiring harness with a obd2a to obd 1 conversion
thekid2390
06-18-2013 11:36 AM
D_koschak
01-21-2011 05:46 PM
SoFresh
12-03-2010 04:24 AM
clark81
09-05-2010 11:52 AM
DumpedSi
07-20-2003 03:19 PM
Quick Reply: si engine harness/ecu harness
