Should i buy these? Difference between ebay and autozone gasket kit?
My car is a d15b7. When i pull two plugs out i'm getting lots of oil. I'm not sure if it's just the gasket under the valve cover or something worse but next time i change the plugs i'll check.
I need to do the valve gasket and i guess the main spark plug tube gaskets under there also. (is there a second set further down? would that set attribute to oil on the tip of the spark plug?)
Autzone sells the kit for 25.99 + tax
Ebay has kits like this, which is just the autozone style kit: (20 shipped avg)
http://cgi.ebay.com/ebaymotors...wItem
* VALVE COVER
* SPARK PLUG TUBE SEAL
* GROMENT
Or kits with more like the head and exhaust gaskets: (38 shipped avg)
This set includes:
* Graphite head gasket
* Intake manifold gasket
* Exhaust manifold gasket
* Valve cover gasket
* Viton valve stem seals
* Camshaft front seals and other small gaskets, seals, and O-rings.
Or kits like this with all that PLUS oil pan and other random stuff that i don't even know what it is: (50 shipped avg)
1. HEAD GASKET SET
2. CONVERSION SET
* Oil Pan Gasket
* Front & Rear Main Seals
* Water Pump Gasket
* Small Components
My question is, do i want these? Are they any worse than the autozone brand? Assuming this second hand civic has had little to no maintenance before me, what all should i look into replacing? (or should i just stick with what i know is wrong?)
* VALVE COVER
* GROMENT
This set includes:
1. HEAD GASKET SET
2. CONVERSION SET
* Oil Pan Gasket
* Water Pump Gasket
* Small Components
get oem parts bro....my buddy replaced his oil pan gasket with a cheap $11 gasket from autozone and next day it started leaking...he bought a oem head gasket and problem solved...point is do it right the first time, you dont want to be wasting time doing things twice...
Re: Should i buy these? Difference between ebay and autozone gasket kit? (willpower102)
goto your local dealer..and buy it there...much better quality and a name you can trust..
expletive that my OEM Acura B18C Exhaust Manifold gasket had a leak when I put it on. Used Felpro from Advanced for cheaper and no more exhaust leak. Advance is a good store.
Re: (StreetRacinThug)
I thought the stuff that advance/auto zone sells meets oem specifications or whatever?
Ive used seal kits from there on my b16 with never a problem anywhere.
AutoZone sells Felpro and ROL gaskets. They can also oder Beck/Arnley products.
TunesEK
01-15-2009 01:35 PM
e_r_i_c_
02-15-2006 07:08 PM
